Finally calibrated my K10D's AF
Smeggypants
Posted 30/08/2010 - 13:15 Link
...and what a difference!!!
A couple of months ago I bought a K10D as a 2nd body to my K20D so I can avoid missing shots while swapping lenses. The K10D was sold with a Sigma 17-70 F2.8-F4.5
I've been disappointed with the 17-70 for a while for it's apparent softness, but last weekend I used it on my K20D and was stunned at the difference.
Anyway a couple of days ago I enabled DEBUG mode using the text file/Door open method and put the K10D on a tripod and aimed it at a car number plate at near infinity down the street.
The K10 originally was set up as it's default 0µm global AF setting. I took 37 shots, each time allowing the AF to search the number plate from a near focus blur, and incrementing the AF setting in 10µm steps up to +360µm between shots.
I did this with all my AF lenses - it was tedious
I then loaded them into lightroom and investigated. The default setting of 0µm was soft as sh*t on all lenses and I found that a setting of 240µm gave the sharpest results for my lenses. There's a lot of leeway really. anything between 190µm and 270µm wasn't too shabby.
It's like having a new camera. I'm wondering if the seller of the K10D and 17-70 put it up for sale because of this softness.
Out of interest I tested the same lenses, using the same method on my K20D and took 21 shots from -10 to +10 on the individual lens AF adjustment ( no need for debug mode this time of course ) and each setting didn't make any obvious difference.
hefty1
Posted 30/08/2010 - 18:43 Link
It is a worthwhile exercise on the K10D - I too noticed a night and day difference after I calibrated the AF on mine, just wish I'd done it sooner...
Joining the Q
cedricd
Posted 30/08/2010 - 21:02 Link
Same here, I was about to trash a Tamron 28 - 300 lens because of poor results on the K10. After assaulting the settings via the Debug Mode and adjusting to +150 the Tamron is fine. Curious though my other lenses don`t suffer with that setting. I now leave the K10 set to + 150 for them all.
Cedric
Enjoy life
i-Berg
Posted 31/08/2010 - 10:28 Link
My K10 is similarly on a permanent setting of +120um, after tripod tests of all lenses in use.
Smeggypants
Posted 10/09/2010 - 16:48 Link
I've just tested my Pentax DA 10-17 after noticing that the K10D AF wasn't focussing properly with it.
This time the optimum setting was +130µm. So I think I'll leave it in debug mode and change the AF if I put the fish eye on.
Again the K20D is almost perfect with the Pentax 10-17
pgweber
Posted 10/09/2010 - 16:55 Link
Do you have a link to the instructions you used and which firmware are you using?
Thanks in advance,
Pentax K5
Tamron 80-210mm & 28mm
Smeggypants
Posted 10/09/2010 - 17:10 Link
V1.3
1] create text file called MODSET.TXT containing [OPEN_DEBUG_MENU] in the DCIM folder of SDHC card. Turn the camera on with the card door open and you'll see the debug menu. here you can enable debug mode.
2] open the set up menu and scroll up and you'll see 3 new parameters. Enter AF test and scroll down to adjust the AF adjustment. I'm not sure what AD test area means in terms of adjustments, I've always left it at 0
3] The adjustment you set remains in place even when you disable debug mode.
Although now I'm going to leave the camera in debug mode so I can alter the AF adjustment between my Sigma and Pentax lenses.
HTH
