Film Scanning problem.
Posted 12/04/2013 - 01:44
Can you explain how it isn't right compared to the original?
Posted 12/04/2013 - 02:27
Posted 12/04/2013 - 13:28
I have an Epson V500 which has a technology called ICE. This can't be used with B&W films as it turns anything close to black into a block of solid black, as well as some other problems. If your scanner has something similar, it could maybe be due to that.
Posted 12/04/2013 - 15:12
Yes, i think Jonathan is right. I am the owner of Epson V500. Actually it is not so easy to make quality scan of B&W negatives. Canoscan has similar technology called Qare. Check if you can turn off "Automatic QARE dust and scratch removal" and try it...
Posted 12/04/2013 - 18:06
Thanks for the help.
Problem solved!
Problem solved!
The scanned image isnt right, has anyone encountered this problem?
i've googled and went on to canons support site.
played with the settings. still the same.
