Fake Epson inks ?
Posted 10/09/2007 - 18:06
How do you know it's fake, and not just a faulty cartridge?
If you click on Help, it tells you clearly how to make a return. You can explain why at the same time.
It also tells you how to contact customer service.
Posted 10/09/2007 - 18:09
You do not make it clear whether it was a purchase from Amazon or from a supplier in the Amazon Marketplace.
I'm sure that in either case if they do turn out to be faulty or fake, then Amazon will want to know about it. They are a reputable business.
Posted 10/09/2007 - 18:36
I had a DVD from amazon last Christmas which was scratched. They were very good about it and replaced the whole box set very quickly.
I'm sure if you contact them they will be very concerned about this and will replace the faulty/fake cart.
but it does help
but it does help
Posted 11/09/2007 - 17:45
I had a look at all the options in the 'Help' section, clicked on one which said 'I have been sent a faulty or damaged order' and it came up with 'Your order is not allowable for return' .....There does not seem to be an 'ordinary' e-mail address or telepone where I can contact them to tell the story and send the photos.
Posted 11/09/2007 - 19:31
http://www.amazon.co.uk/gp/help/customer/display.html?nodeId=1161016
I would say you would think you've been sent a defective item. Halfway down, on the right hand side of this page is a 'contact us' link, which promises "Express customer service or contact us by e-mail or phone".
Dan
Dan
Posted 12/09/2007 - 21:37
I hope its not the same issue I came across with HP cartridges that although the printer was boxed and sold in England, when the first set of replacement cartridges were required it turned out the printer was set up for another region and had to be reprogrammed for use in England.
Barry
Posted 13/09/2007 - 12:25
Daniel : I found the link where you told me and had a go at 'e-mailing' them - well, what a palaver ! An hour spent searching out papers from the original order, typing in all the story with pasted in photos as on here, then when I pressed 'send' it would not go as it said the order number had not been recognised- I kept on checking, then put in the number on the paper where the inks were, still would not allow it to send ! Had to give up as I had to go out. Will try to telephone but will probably get an hour of music before getting through!
21 years
Brentwood Essex (UK)
[Open Image] [Hosted by PhotoGalaxy.com]
