failing lithium battery
mastaff
Posted 18/03/2011 - 11:33 Link
Dear All,
advice would be much appreciated. I purchased a new K-7 January '10. Not much use - only about 1800 actuations. Now the battery is failing after about 150 shot and needs recharged. Camera just jams and dies- although LCD disply remains on top - even when turned off. Works OK when recharged, but only for another 150 shots or so
Is this a faulty battery and should it still be under warranty? Just checked - £60 to replace.
Thanks in advnce
Michael
bretti_kivi
Posted 18/03/2011 - 12:45 Link
you charged it properly, right?
so that means fully charging, fully discharging, and repeating that for *at least* the first three charges?
Storage for long periods in a fully charged state? If not, you've broken it and you can try arguing for a new one, but I wouldn't bet on it....
Bret
my pics: link
Cisco
Posted 18/03/2011 - 13:04 Link
Never heard of that before for 'Li-ion' batteries :
Quote :
Lithium-ion is a very clean system and does not need priming as nickel-based batteries do. The 1st charge is no different to the 5th or the 50th charge.
K-7 | K10 | DA 18-135 | DA 18-250 | DA 55-300 | DFA 100 |
Edited by Cisco: 18/03/2011 - 13:08
gartmore
Posted 18/03/2011 - 13:49 Link
How much do you use the LCD screen? Live view and lots of reviewing will deplete a battery quite rapidly.
pentaxian450
Posted 18/03/2011 - 14:12 Link
If the LCD display remains, you might have a fault with the camera. When the battery dies, everything turns off.
If you know anybody doing electronic work, you can ask him (her) to do a load test on your battery BEFORE and AFTER the camera dies on you, so you'll know for sure if you have a problem with the battery or the camera.
greynolds999
Posted 18/03/2011 - 14:19 Link
Is the firmware up to date?
mastaff
Posted 21/03/2011 - 00:09 Link
Thanks to all for the comments - very much appreciated. Battery was fully charged/discharged. Firmware up to date. Not covered by warranty. Looks like I need to replace. Better luck next time.
