F Numbers and Shutter Priority
tyronet2000
Posted 12/07/2012 - 23:09 Link
This evening while trying out longer exposures I was using shutter priority at 3 seconds and the screen was showing I needed an apeture of f/40 which as far as I know isn't available on the lens I was using. Several other shots gave readings of f/29, f/34 etc. A photo was captured ok so is there some sort of wizardry at work or does the lens just go to f/22. Also could using the camera when these way out readings are showing cause damage to the camera and/or lens
Stan
vic cross
Posted 13/07/2012 - 10:00 Link
I don't know the answers to your questions but to avoid the high f stops why don't you just UP/DOWN the ISO?
CHEERS Vic.
Edited by vic cross: 13/07/2012 - 10:01
fatspider
Posted 13/07/2012 - 10:24 Link
You really need to engage brain before making posts Stan, letting us know what lens was attached would help
If it was a Sigma or other third party lens then that may have something to do with it, the Sigma 50-500 for instance is supposed to have a max aperture of f6.3 at 500, but will never register below f6.7.
It could also be a fault with the electronics in the lens, even possibly dirty contacts, I would start with cleaning the contacts on both lens and body and then give the combo a thorough workout.
Another thought, did you have a third party grip attached?
My PPG link
My Flckr link
tyronet2000
Posted 13/07/2012 - 10:49 Link
K5 on a tripod with Pentax 18-135mm ISO 200 Tv 3" Filters (Kood) 1 x ND2 1 x ND4 (Unknown) 1 x ND4 in that order. The object of the exercise was to smooth out the waves and see how the time would affect the exposure. It was a beginners class run by a club member (Canon user)
The exif in this shot shows f/40 at 3 secs and photo shows a lucozade bottle in the bottom left which may or may not have contained a message
untampered jpg
[IMG]http://i1100.photobucket.com/albums/g406/tyronet2000/_K5_0677.jpg[/IMG]
Stan
Edited by tyronet2000: 13/07/2012 - 10:54
fatspider
Posted 13/07/2012 - 12:57 Link
Perhaps it was to tell you what was wrong with the camera
My PPG link
My Flckr link
tyronet2000
Posted 13/07/2012 - 16:44 Link
Think I've sorted it out. Thanks.
Stan
