Extra kit for a newbie with a k200d
Posted 08/04/2009 - 13:41
wooly jumper £25.
But if you are the hardy type, forgo the wooly jumper and get a set of extension tubes and a 50mm manual lens to play about with macro, about £25 all in off ebay.wooly jumper £25.
Davex.
Posted 08/04/2009 - 13:49
Have a couple of fairisle's in my cupboard that will do....
Thanks for the post, seems better than I thought in terms of what my grand national scoop can get me. Are the remote and filters useful for a beginner or would I be better served spending it all on the lens?
Posted 08/04/2009 - 14:02
You can reproduce a lot of filter effects in Photoshop but personally I prefer to get it right at the time of taking the image, a set of grads and a few neutral densities will do this for you. You will learn a lot by using using them.
You can spend as much as you like on lenses but the 16-45 is a good addition to the kit lens, assuming you have the 18-55. Off course you can spend hundreds on Macro lenses but they are a bit limited in what you can use them for. Have a good look at ebay, you can pick up some decent manual lenses for not a lot of cash, this will allow you to experiment initially while you decide where you want to go.
Davex.
Davex.
Posted 08/04/2009 - 14:06
If you already have a tripod the remote will help a great deal. A polariser is always a good investment: bluer skies, cutting reflections, colour saturation generally and doubles up as a ND filter for longer exposures.
Although replacing the kit lens with the 16-45mm is one possibility, you could expand your choices with either he 50-200mm lens (129 pounds from SRS) or getting the 55-300mm lens (195 pounds). I personally like my kit lens and have decided to expand my lens choices first before replacing it.
Posted 08/04/2009 - 14:19
For landscapes, GND filters can be helpfull.
With a such a system as cokin you can decide were the transition of the filter is and such. To fit it on another lens you only need a small ring instead of buying new filters so that's a good investment for that money.
The also sell a set with the holder and 3 variations of GND filters they are quite cheap.
Polarization filter is also very handy outdoors, just search on internet what it does with the flora and the sky and you will see why you want one. The only bad thing is that they are expensive though.
It seems btw that you can use linear filters without any ill effect so try it I would say, they are a lot cheaper.
The kitlens is a very decent lens, simply look here and you see what I mean link
You might better use it for a couple of months and for now buy a second-hand pentax A 50mm f1.7 lens so that you get a feel what a fast prime does. After that you've a far better understanding what you want to do.
Here is a decent looking lens link
ps. Kris idea is also great get the 50mm and the 55-300 and you've a kit that covers alot of things.
Posted 08/04/2009 - 14:20
I'm with Womble on this, I recently bought the 16-45 and didn't think it much of an improvement on the 18-55 at all, although others do think differently. The 55-200 is a cracking lens and isn't much bigger than the 18-55
Given your tripod was bought for a bridge camera I suspect it might be a tad flimsy, get the sturdiest tripod you can afford - I've had mine for 30 years!
Posted 08/04/2009 - 14:38
I'd go for the 55-300. Just bought one myself and very please with it. A good tripod is a must plus the neutral density graduated filters.
Posted 08/04/2009 - 14:41
I did have a look at the 55-300 with interest. I'd like something that offers more scope than I currently have while I'm learning.
Did think about manuals but I'd heard that there was a dust issue with going that route (?) Not sure I follow the logic now I've typed it though.
The tripod I've got is pretty bomb proof, my bridge looked slightly ridiculous on it....
Posted 08/04/2009 - 15:08
I'm very happy with my 55-300mm. I was never that impressed with my 50-200mm - it never seemed very sharp - but some people seem to be, so there seems to be a bit of variation.
I haven't tried lunar photography with it, but even with a 300mm lens the moon doesn't look that big. You could probably get a reasonable result with a bit of cropping, but don't expect it to fill the frame.
I use quite a few old manual focus lenses - I'm not aware of any issue with dust. Obviously you wouldn't want to put something filthy on the front of your camera, but if it looks pretty clean then I don't see what the problem is.
Posted 08/04/2009 - 15:24
I think that the advice about dust must have come from someone who'd had a bad experience, doesn't make sense to me either. The lunar photography is by no means a priority, maybe something for the future.
Posted 08/04/2009 - 17:03
Dust normally gets on the sensor when you change lenses - it doesn't matter if the lenses in question are auto or manual, old or new. It's all down to how careful you are and whether the lens in question is covered in muck...
Joining the Q
Quite unexpectedly I've now got £300 to spend on extras and I'm looking for advice for expanding my kit. I've got nothing except tripods from my bridge camera days.
I'm mainly interested in outdoor photography, both big scale landscapes and small scale (close ups of plant life etc) I'm keen to keep as flexible as I can though and I'm also interested in architectural photography. I've also been seduced by lunar shots I've seen so I'm leaning towards a telephoto. But I wanted to get some ideas before I bought anything.
I'm thinking I'd be able to get a new lens and maybe some extras (filters: circular polarizer for nice skies? Remote: So I can use long exposures) I might be being wildly optimistic so if that's the case let me down gently.
So to the question. If you had no kit and £300 to spend what would you get?
