extension tubes
Posted 04/09/2008 - 18:36
I think they were correctly described, I'm afraid. 'Auto' here refers to automatic diaphragm. There are others around here much more knowledgable than me about things macro but I'm sure auto focus extension tubes dont exist and the reason for the absent contacts is that these tubes are designed for the (film) K and M series lenses and bodies. No idea as to price.
Posted 04/09/2008 - 18:57
They were correctly described. Auto as in diaphram. to my knowledge, only kenko had an af (screw drive) extension tube for pentax. Buy yourself a pentax af 1.7 teleconverter, and stack the converter, then the smaller auto tube and then a 50mm lens, for a decent (if slow) af macro set-up.....
Posted 04/09/2008 - 20:05
I made the same mistake as you, this week actually, mine arrived 2 days ago - they are exactly the same as those in the pic.
For some reason I haven't been able to take a picture with them - or rather every image just comes out black even though everything looks ok through the viewfinder (I'm attempting to use my SMC-A 50mm). Have you managed anything with yours yet? I will keep trying with them (at least I'm having fun!) - I'm sure there is something obvious I'm missing
I paid around £20 with p&p for mine but don't think they are in as good condition as yours. The most annoying thing about mine is that the picture on the ebay is obviously a newer model as it had different clips and generally just looked a little more modern.
edited due to dodgy spelling
gartmore wrote:
'Auto' here refers to automatic diaphragm.Ken
Sorry for the daft question - but what do you mean by auto-diaphragm, mine doesn't seem to do anything automatically?'Auto' here refers to automatic diaphragm.Ken
Posted 04/09/2008 - 20:10
see the spring attached to the lever inside the mount?
that pull your lens aperture wide open to let in as much light as possible (when viewing/focussing), and when the shutter fires it AUTOmatically stops the lens down to your chosen aperture.
Posted 04/09/2008 - 20:13
Thanks Don - I'd flicked that spring and assumed it must do something but couldn't see what.
Posted 04/09/2008 - 20:45
Woodworm
My images to came out black,but with flash it does work.I want to use mine with my tamron 90mm macro to get even closer.
I think we will have to adjust tv value to let more light in.
Oh well another learning curve
Roy
Roy
regards
Roy
Pentax K3 gripped,and some lenses
https://www.flickr.com/photos/pentaxroy/
my pbase gallery
Roy
my pbase gallery
Posted 04/09/2008 - 21:16
Here are two examples with very similar tubes and a Pentax M 1.7. The lens was at its widest and manual focus, but I can't rememeber the no. of tubes I used. They are hand held in the garden with a breeze blowing - probably a lesson in how NOT to take macro and will make the experts cringe. :blushBut one has to start somewhere)
[IMG]http://i83.photobucket.com/albums/j311/Tinywales/garden/spider_1.jpg[/IMG]
and
[IMG]http://i83.photobucket.com/albums/j311/Tinywales/garden/spider_2.jpg[/IMG]
Howard
and
Howard
Cymru Am Byth
Posted 04/09/2008 - 21:56
Pentax A compatible tubes are worthwhile, but AF? I don't think they are at all necessary as most macro shots require MF.
FWIW, I have a set of Kenko tubes marked as Pentax AF compatible. They are that, but only in MF mode because they lack the screw drive coupling.
Confused? You will be.
Posted 04/09/2008 - 22:26
The genuine Pentax Auto Extension tubes have exactly the same - aperture levers, but no metering contacts.
I have some "Triplus" tubes that do have the contacts. Very helpful (but not AF - which they don't need to be).
So there are some out there...
Posted 04/09/2008 - 22:55
I brought mine thinking they were AF, they are Kenko brand with "for P/AF" stamped on the side. But it was obvious when i looked at them that they don't have the AF screw drive
So what does the AF stand for if not auto focus.
Camera:|K-7|
Posted 04/09/2008 - 23:22
I may have been wrong about the kenko having af coupling....but they definately have a 25mm with electrical contacts for metering, with the a, and af lenses.
Posted 05/09/2008 - 14:08
Yep those were the ones i thought i was getting.
Too late now but i will learn how to use the ones i have.
Roy
Roy
regards
Roy
my pbase gallery
Roy
my pbase gallery
Newport,
South Wales,U.k
Not sure if this is the right forum for this question.But can someone please confirm or otherwise that these are indeed NOT auto focus or exposure ( i bought them from ebay described as auto extension tubes it also says so on the box "Jessops auto extension tubes for pentax k fit) so i have emailed the seller waiting for an answer as perhaps he was mis-sold them in the first place,,but thought i would get more "expert" advice on them.There are no electrical contacts at all on them.Also what would they be worth if not...i paid £30 inc p and p.
Roy
edited for "exposure"
Roy
my pbase gallery
