Extension tubes
Posted 04/09/2012 - 19:54 Link
I've just bought some extension tubes and had a little play with them, but not sure if what I need to look at when using them, ISO etc.
I've attached 3 pictures, the first just didn't come out right, the 2nd and 3rd are ok, btw the leaf was really small
Body: Pentax K-r & K-3 + D-BG5 Battery Grip
Lens: Pentax 18-55mm L - Pentax 18-55mm AL WR - HD PENTAX-DA 15mm F4 - Sigma 18-250mm f/3.5-6.3 DC OS HSM - Sigma 50mm EX DG Macro - Sigma 150-500mm f/5-6.3 DG OS HSM - Kenko 2x Teleplus
Flash: AF-360FGZ
davidstorm
Posted 04/09/2012 - 20:11 Link
Hi John
You will need to be patient and practice a lot with the extension tubes. They take some getting used to, but will yield great results if you stick with them. The best advice I can give is:
- Light is all important, you lose some with tubes so you need good daylight (sunlight preferably) or a decent source of diffused flashlight
- A monopod is useful for stability and flexibility of positioning
- Hold your breath when taking the images, any slight movement is magnified with tubes
- Use apertures of F11 upwards - you need this to get a decent depth of field
Keep at it and I'm sure you will get some stunners.
milamber
Posted 04/09/2012 - 20:33 Link
Hi John
I use the 'catch in focus' feature on the K-r most of the time when taking macros with extension tubes. Some people prefer not to use it, but I find it gives me a higher success rate (though I have plenty of duds as well).
Might be worth a play with and see if it helps, but as David says, lots of practice is best.
Posted 04/09/2012 - 20:40 Link
I will try and find something in the garden to practice on, should be better than the light in the house
Flash: AF-360FGZ
dougf8
Posted 04/09/2012 - 20:53 Link
Re: the light
Buy some pringles and eat them. ( or the own brand knock offs).
The tube (silver inside) can then be cut up and used as a light guide for the on board flash and directed to where your subject is. Plenty of stuff on the www about it.
you'll need in addition, couple of rubber bands, some black tape and sharp scissors, maybe a thin white sheet (e.g. plastic bag)
I've got as far as eating the pringles....
Lurking is shirking.!
Edited by dougf8: 04/09/2012 - 20:53
Posted 04/09/2012 - 20:55 Link
Thanks Doug, I thought you was describing an episode of Blue Peter
Flash: AF-360FGZ
dougf8
Posted 04/09/2012 - 20:57 Link
I had a prototype in the garden a few nights ago but holding a torch, then trying to focus manually on an over active moth was a bit too hard.
http://www.google.co.uk/#hl=en&output=search&sclient=psy-ab&q=pringles+flash+macro
I'm aiming for the hotblack desiato style like this
Edited by dougf8: 04/09/2012 - 21:01
davidstorm
Posted 04/09/2012 - 21:13 Link
dougf8 wrote:
Re: the light
Very good advice. Here's one I've made, although this is for hot shoe flash, not the on-board version. This is about the fourth or fifth prototype and the most successful to date as it has adjustable tubes and fires flash from two directions, hence no shadows. I can get F16 at ISO 200 with this = perfect for macros with tubes attached.
Best wishes
Posted 04/09/2012 - 21:15 Link
I'm going to have to try this
Flash: AF-360FGZ
Charlotte
Posted 04/09/2012 - 21:17 Link
Here's one on an on board flash.
Keep practising 'tis fun.
dougf8
Posted 04/09/2012 - 21:33 Link
Charlotte has saved on the rubber bands just using one and has trapped what looks like tracing or grease proof paper under the original cap, saving a bit of tape. Very economical.
Pimp my tube ... to be fair David's looks like three tubes. I'll have to wait for a bogoff to try that.
I'm guessing David has also got 45 degree reflectors in the elbows too?
Edited by dougf8: 04/09/2012 - 21:39
nass
Posted 05/09/2012 - 09:48 Link
Possibly the ugliest home made diffuser I've seen, but I bet it's also the best (2 directions). Shame there's no pentax compatible flash like the mp-e 65 dedicated one. I use something similar but not as good I think
davidstorm wrote:
dougf8 wrote:
Re: the light
Best wishes
Charlotte
Posted 05/09/2012 - 10:39 Link
This was my latest contraption, it worked quiet well and enabled me to get light under leaves because I could adjust the direction and the angle the flash was pointing;
Probably have to sell the lot now I don't have a camera that works.
Hey ho.
dougf8
Posted 05/09/2012 - 10:47 Link
You can pick up a GX10 for under £150.
nass
Posted 05/09/2012 - 16:16 Link
Your cam died charlotte?
