Exposure problems with Pentax K-500
Posted 26/08/2016 - 22:14
One possibility is that you are set to spot metering. If this isn't used as intended exposures will be all over the place. To be absolutely sure what is happening some sample images would be helpful as it just might be a consequence of the type of subject as well.
Posted 27/08/2016 - 08:57
aperture motor falure?
If you look in to the front of the lens can you see the diaphragm stopped down?
Nr Elgin
bobmartin
