Exposure problems with new focusing screen
giofi
Posted 09/05/2010 - 19:02 Link
I recently bought a new split image focusing screen for my K20D from Focusingscreen.com (K3 model). I find it very good and I am very happy with it.
Today I put a Pentax FA 100-300 on the camera and found out that it overexposes by some 3 stops with the new focusing screen. The same happens with the FA 28-105 zoom.
After some testing I found out that the focusing screen works fine with some lenses, but not with others. The only commonality I found is that it works fine with fast lenses (for instance the DA* 50-135, but I have not tried all lenses).
Do you have any ideas and recommendations? I have read many reviews about Focusingscreen.com and this particular focusing screen, and no one reported similar problems.
Thanks to anyone who can help....
Anvh
Posted 09/05/2010 - 19:13 Link
It's a known problem with split-screen focusing screens.
Here this how every thing is placed inside of the camera.
#1 is the exposure meter
#4 is the focusing screen
#7 is the AF sensor.
I believe the rest is quite clear.
As you can see the exposure meter must meter though the focusing screen and that's causing the problem.
Stefan
K10D, K5
AF-540FGZ
giofi
Posted 09/05/2010 - 20:57 Link
Thanks Stefan.
But is it normal that the problem exists only with certain lenses and not with others?
womble
Posted 09/05/2010 - 21:12 Link
Were you using spot metering? I have only heard of problems with spot metering and split screens, not with specific lenses. Mine seems to neter fine with the katz-eye screen I bought from axl.
Best wishes, Kris.
giofi
Posted 09/05/2010 - 21:29 Link
Thanks Kris! Yes I was, now I tested with center weighted average and it seems to work fine. Problem solved.
Reading on KatzEye's site I also found the explanation of the difference between lenses:
Spot Metering Mode: Our testing showed spot metering mode to be within factory tolerance for all AF lenses having a maximum aperture of f2.0 or larger (lower f number). Lenses having a maximum aperture smaller than f2.0 (lager f number) will show a significant shift toward increased exposure, with the shift increasing for lenses with smaller maximum apertures. Spot metering mode is NOT RECOMMENDED when using a split prism focusing screen with lenses slower than f2.0.
womble
Posted 09/05/2010 - 21:31 Link
Glad to be of service!
Having a split screen again has been bliss as far as I am concerned.
Best wishes, Kris.
giofi
Posted 09/05/2010 - 21:56 Link
Kris,
I fully agree with you.
