Experimenting with CPL filter in late evening light.
Posted 13/03/2011 - 22:23 - Helpful Comment
I'd make it a B&W
Posted 13/03/2011 - 22:34
Actually didn't occur to me, because I liked the sky colours. But in fact black & white is nice. (Just a quick conversion, didn't mess with the contrast or anything, not sure it needs it).
[IMG]http://i1204.photobucket.com/albums/bb411/msitaylor/EveningTreesCPLrbw.jpg[/IMG]
Posted 13/03/2011 - 23:17
Surreal silliness:
[IMG]http://i1204.photobucket.com/albums/bb411/msitaylor/EveningTreesCPLreflection-r.jpg[/IMG]
Posted 14/03/2011 - 01:37
I like the mirror sillyness. It's not silly at all
It's quite cool rotated 90 deg CCW too
Posted 14/03/2011 - 09:19 - Helpful Comment
The title suggests you were experimenting with a CPL filter, which is only any good to control polarised light if there is any. I'm not sure there would be any here, but it would have enabled a longer exposure time by cutting down the overall amount of light.
You could also try running together the "relection" with the main subject, eliminating the land, and see what that gives you.
Posted 14/03/2011 - 12:35
I did try a couple of shots without the filter and the hue of the sky was visibly more intense with the filter, and even more so than viewing the scene with the naked eye (actually the bespectacled eye in my case) so I'm guessing there must have been some polarised light around... or is it possible that this is just due to cutting down the amount of light as you said? I'm not very familiar with the exact effects of filters as haven't really used them before.The title suggests you were experimenting with a CPL filter, which is only any good to control polarised light if there is any. I'm not sure there would be any here, but it would have enabled a longer exposure time by cutting down the overall amount of light.
I don't know how much bearing this has on the quantity of polarised light about, but actually it was not that late in the evening. However, any much later around here and there wouldn't have been much light to speak of as the sun goes down like a lead balloon around here at this time of year. Checking the EXIF against the 'official' sunset time (18:11) it was about 6 minutes after sunset (18:17). The clock on my camera is set pretty accurately.
Posted 14/03/2011 - 13:03 - Helpful Comment
As a photo it doesn't do much for me, but I like the surreal one.
I have photos from Norway, without CPL which have just as blue a sky, so I doubt the CPL made much difference.
In fact I thought the white balance was way out on them and corrected them, even ones taken before dawn/after sunset looked better for WB correction.
Now if you were in the tropics I could understand the lead balloon comment but in Edinburgh? In Norway there was at least an hour of twilight, followed by a good half hour of "blue light" and here, quite a bit further south than you we have quite a long twilight period followed by a longish time of blue too.
Posted 14/03/2011 - 13:28
Edinburgh is very hilly so perhaps the shape of the landscape tends to occlude the remaining sunlight more. Also I don't know about Norway but it is almost always heavily overcast here, pretty much all of the time for at least 8 out of 12 months (October - May) so that probably contributes too. I assure you by the time I got home (about half a hour later) it was properly dark.
As for 'blue light' my wife is from Australia and she constantly complaints that so far as the sky is concerned, there is no blue to be seen around here!
Posted 14/03/2011 - 18:17
Checked the white balance setting and apparently the camera was set on Automatic - which is strange as I could have sworn I had it set manually on 'cloudy' the whole time and most of the other shots from that day show that it was.
However, no matter what camera 'preset' white balance setting I select to apply to the RAW file (I am using the Pentax Digital Camera Utility for this purpose) the sky is still a more intense colour than any of the other shots I took around the same time and place, and the 'Daylight' setting looks identical to the original. Surely the filter must be having some effect for this to be the case?
I'm also not sure why folks are so quick to rule it out considering intensifying blue sky colour is supposed to be one of the uses of a CPL filter. I know I'm a beginner at this stuff so any explanations would be appreciated as they would help me to learn!
Posted 14/03/2011 - 19:22 - Helpful Comment
You don't need the CPL filter at night. The Blue Cast is what's known as the Blue Hour. See this site for details:
You can get the time of the Blue Hour from this site.
Posted 14/03/2011 - 21:01
Thanks Algi, that's useful information. According to the timings I took the picture a bit before the 'blue hour' but I'm sure it must vary depending on atmospheric conditions etc.
Posted 14/03/2011 - 21:26
There's probably a bit of leeway with the times
This is a very beautiful photo, then it just became better (IMHO) when turned to B/W, and you adding that surreal effect, wow, just plain magic.
Would look very nice in a gallery!
Edinburgh,
Scotland
[IMG]http://i1204.photobucket.com/albums/bb411/msitaylor/EveningTreesCPLr.jpg[/IMG]
