Exif data format for K10D
Posted 31/10/2008 - 16:22
The best thing is to download PhotoME
http://www.photome.de/download_en.html
It displays _everything_ inside the EXIF (including camera temperature and serial number!!). AFAIK the data files it uses are XML format - so you can unpick it.
You'll have fun reading EXIF tags - there are such a huge number!
There are also plenty of freeware tools and libraries for EXIF reading anyway - so do a Google before you start coding
Hope that helps!
Hope that helps!
Posted 31/10/2008 - 16:32
Thanks Matt,
I have down-loaded PhotoME and seen some of the data available.
I am trying to look at all of my photos of one particular type of subject, to see if the focal lengths I have used are covered by a possible new lens purchase.
The number of photos is too large to contemplate opening each in PhotoME, so I am thinking of going the programming route to automate/speed-up the analysis (and I like a computing challenge now and again).
Regards,
Regards,
Pentax K5
Tamron 80-210mm & 28mm
Pentax K5
Posted 31/10/2008 - 17:16
No problem Peter.
It's almost certainly all done for you. Check out these links:
http://www.suodenjoki.dk/us/archive/2008/extract-exif.htm (with Javascript)
http://www.br-software.com/extracter.html (extracts info to CSV file)
http://sourceforge.net/projects/libexif (developer library)
http://www.instituteofthefuture.org/exifomatic/ (Java one)
http://www.kuren.org/exif/ (C++ source code)
That should get you started
Others are listed here.
Have fun!
PS. Or in true Pentax LBA style... just buy the lens!
Have fun!
Posted 31/10/2008 - 20:59
PS CS4 can filter by any/all the EXIF data, by default it shows Focal length (thats the actual focal length selected if using a zoom), Aperture, White balance, Exposure time, Colour profile and the Raw converter settings (if named and saved). Any EXIF parameter can be added/removed to/from the list.
I wouldn't be surprised if CS3 and even CS2 can do this too, I have never checked, you could write a script to do it any version of Bridge (I believe) - well a better man than I probably could, but its default in the CS4 version of Bridge.
Chris
Chris
Chris
Nottinghamshire
Does anyone have a listing of the data items and their associated variable types (i.e. ASCII, long, integer, etc) embedded in the jpg files produced by the K10D.
I want to analyse how my photos break down by focal length (& other parameters) which I thought I could do by writing a little programme to read the exif data, but need to know the data structure.
Thanks in advance for any help,
Pentax K5
