email help
jimmoore
Posted 02/07/2012 - 11:57 Link
PC email help,(for use with Pentax of cause)
Can one of the onboard experts help a computer dumbo with a problem?
I have until recently used the offsite spam protection service Clear my mail, this intercepts my mail checks it and I collect it from them.
I have new decided to stop using this facility, and from that date I sometimes get email attachment a text, but not all the time.
It must be a setting in outlook but I don’t know what to change to stop this.
Is there anyone who can help.
Jim
greynolds999
Posted 02/07/2012 - 12:14 Link
It sounds like you need to change your MX records. Which is a complicated process and dependent on who hosts your mail.
Who do you use for email?
jimmoore
Posted 02/07/2012 - 12:17 Link
I am using Plus
steven9761
Posted 02/07/2012 - 14:08 Link
Jim - by "PLUS", are you referring to YAHOO PLUS??..
jimmoore
Posted 02/07/2012 - 15:10 Link
No Plusnet the Yorkshire people advertising on the TV (part of BT I believe)
could this also be effected by look at mail on my I-Pad?
JIm
steven9761
Posted 02/07/2012 - 15:39 Link
Not sure of Plusnet's set-up, but if you first have a look in your list of OTHER PROGRAMS (from your start menu), then see if Plusnet has a program file listed there, click on it (if it exists) to expand it, then see if there is a line similar to "UNINSTALL PLUSNET EMAIL" (or similar). If so, click it to start the uninstaller.
If the above doesn't help, phone Plusnet's customer services team - they should be able to talk you through it, or even remotely access your screen (with your permission) to uninstall it for you.
Finally, if you are using Outlook as your default mail program, click on the tab that allows you to ADD/REMOVE EMAIL PROFILES, then simply delete the Plusnet account, then set A.N. OTHER as your default email provider.
Edited by steven9761: 02/07/2012 - 15:42
jimmoore
Posted 03/07/2012 - 08:44 Link
Thanks for you help, both, will see what Plusnet can do to help.
Jim
jimmoore
Posted 09/07/2012 - 15:09 Link
I would if I knew what my MX records are.
Where would I find those?
My laptop is fine my work computer is not, both on the same service provider and both running SM outlook.
Posted 09/07/2012 - 16:04 Link
Can you change your last post to a PM please Steven, it's absolutely full of e-mail links which is not a good thing on a forum.
Many thanks.
steven9761
Posted 09/07/2012 - 16:25 Link
Sorry, John.. I'll PM now...
