Eclipse fluid compatibility
Posted 21/07/2009 - 19:43
You should be using E2 with the K200D according to the manufacturer's compatibility chart here:
http://www.photosol.com/cameras_bymfg.html
Posted 21/07/2009 - 19:59
Thanks,
Back to the shop tomorrow, at least I haven't used it yet.
Greg
Greg
Posted 21/07/2009 - 20:19
Would one not have to be rather vigorous to get the fluid on the sensor?
Posted 21/07/2009 - 20:35
That went though my mind as I believe that what one is cleaning is actually the glass filter and not the sensor itself, perhaps the liquid can flow behind the glass to the sensor by capillary attraction.
Greg
Greg
Posted 21/07/2009 - 20:42
The dominant use of stannous oxide is as a precursor in manufacturing of other, typically divalent, tin compounds or salts. Stannous oxide may also be employed as a reducing agent and in the creation of ruby glass.
I think we can assume that the protective glass is made of that.The dominant use of stannous oxide is as a precursor in manufacturing of other, typically divalent, tin compounds or salts. Stannous oxide may also be employed as a reducing agent and in the creation of ruby glass.
ps. Stannous oxide = Tin oxide
Posted 21/07/2009 - 21:40
As per the Stannery Parliament, true rulers of God's own land - or is that Mebyon Kernow
Pretoria,
South Africa
After much lurking and browsing, my first post.
Doing a search on all the sensor cleaning discussions I came across a statement by Daniel Bridge here, link that Eclipse fluid is not compatible with a K10D sensor.
Could Daniel or someone please elaborate, as I've just bought some to use on my K200D, what should I be using?
Greg
