Easy method to find shutter count
Peter Elgar
Posted 28/01/2012 - 10:33 Link
In 'Amateur Photographer' magazine there was an article on how to find the number of Shutter Activations -- easy ! go to www.myshuttercount.com and upload a copy of the last photo taken and it comes up with all the exif data and shutter count -- I found my K10D was 12,486 from new.
DanielH
Posted 28/01/2012 - 21:58 Link
shame it dosent work for my k-r jpegs
felix
Posted 29/01/2012 - 06:28 Link
It should work for all Pentax jpegs
SteveLedger
Posted 29/01/2012 - 12:37 Link
Doesn't work with *istDS JPEGs
Invalid parameters, please contact [email protected]
However, this one works fine: http://www.camerashuttercount.com
Edited by SteveLedger: 29/01/2012 - 12:40
Peter Elgar
Posted 30/01/2012 - 16:50 Link
Thanks for THAT 'Link' -- I tried it and the shutter count was the same as the one on 'AP'magazine -- 12,486 ( I have not used my K10D since ! )
Mike-P
Posted 30/01/2012 - 20:58 Link
With these type of things you normally need to use unprocessed jpeg (or raw) files.
Posted 30/01/2012 - 22:36 Link
Having set my cameras to continuously record the file numbers, is not knowing the latest file number enough? The only thing that would need to be remembered is how many times the camera has rotated beyond 9999 and as it creates a new folder number at that point even that should not be a problem.
philstaff
Posted 30/01/2012 - 22:46 Link
Just did a check on my Kr 7577 no problem getting the info.
Ian
philstaff
Posted 30/01/2012 - 22:59 Link
philstaff wrote:
Just did a check on my Kr 7577 no problem getting the info. 12146 K100D
Ian
dinneenp
Posted 31/01/2012 - 14:57 Link
thanks.
Frogherder
Posted 01/02/2012 - 17:03 Link
Like JR I use the image numbers the camaera allocates.
The latest one is IMGP 100-8425
This programme comes up with 8783
A variation of 358?
The K10D was brand new when I received it, in a sealed Pentax Box,
I've occasionally done some multi-exposure shots which might have made a difference, but nowhere near that many.
I am perplexed
Bernrad
fourfivesix
Posted 01/02/2012 - 19:41 Link
Forgive me for asking silly questions, I'm still quite new to all this I've noticed when I view images on my camera it says 100-5563, is that how many images it has taken and what does the 100 mean?
Thanks in advance
flickr
link
Posted 01/02/2012 - 22:51 Link
The 100 is the folder and the 5563 the file number. Assuming you have the camera set to continuously count then you have shot up to image 5563.
Frogherder
Posted 01/02/2012 - 22:59 Link
So John,
Is it a count of the number of "delivered" pics or shutter presses.
I have noted for example that multi-exposure shots make take several presses but only deliver 1 pic.
As I said I'm perplexed, am I the only one out of step. Could it be that my camera was "used" a few hundred times before being reset and boxed (doesn't seem likely)
Bernard
Incidentally Photome gives a count of 8783 for the same pic - so some agreement at least
Edited by Frogherder: 01/02/2012 - 23:02
Posted 01/02/2012 - 23:11 Link
It's the number of delivered frames that you have shot. Whatever happened before at the factory is another matter and maybe some cameras are tested more thoroughly than others.
I'm not sure it matters much as it's not so much different to a new car having mileage on the clock when delivered to the customer.
