DPI ON EPSON PX720WD
Posted 28/01/2012 - 17:45
Hi Dave, which menus are you referring to? I have this printer and it is capable of 5760 x 1440 resolution. When you are printing make sure you use proper photo paper and select one of the top two options 'Epson Ultra Glossy' or 'Epson Premium Glossy'.
This printer is superb and I doubt if you will be disappointed with the results. BTW I use non-genuine refillable inks that cost a fraction of the Epson genuine ones and I can't tell any difference. Signal Inks on ebay are excellent quality.
Posted 28/01/2012 - 20:12
Thanks David
In photo elements FILE/PRINT/CHANGE SETTINGS/PHOTO PAPER it appears not to mater which grade you still end up with 720dpi. PAPER SIZE/CLICK ADVANCED SETTINGS/EPSON BOX OPENS/CLICK BEST PHOTO BUTTON/CLICK ADVANCED TAB/CLICK ICM BUTTON/CLICK OK/CLOSE CHANGE SETTINGS BOX/CLICK MORE OPTIONS BOTTOM LEFT/CLICK COLOR MANAGMENT/COLOR HANDLING-(PHOTOSHOP ELEMENTS COLOR)/IMAGE SPACE-(ADOBE RGB 199/PRINT PROFILE-(WORKING RGB-ADOBE RGB 199/RENDERING INTENT-(RELETIVE COLORMETRIC) CLICK OK.
You then go back to the box with your photo in the middle. to the right are drop down boxses 1 PRINTER/2 PRINTER SETTINGS THIS HAS THE PAPER TYPE AND PRINT QUALITY SETTINGS which is set at 720dpi for photo paper or 360dpi for plain print paper.
Dave
Dave
Posted 28/01/2012 - 20:39
Hi Dave
I don't use Photo elements but it sounds like the software is restricting the printer to certain settings only. I print from a variety of programs including Paint.net, Microsoft Digital Imaging and the Epson Easy Photo Print software that came with the printer. All of them work fine and do not restrict the DPI. In any case, you should not need more than 300 pixels per inch for even the highest quality printing, so I don't think you will have a problem. BTW, Pixels per inch and dots per inch are not the same thing.
Best thing to do is print out some of your pics A4 size; you should not see any discernible pixel structure unless you get really close or use a magnifying glass.
Posted 28/01/2012 - 21:13
THanks again
I set the prints to 300ppi to print.
I can not seem to open epson easy photo print. i just get a pale blue and white box with nothing in it if i click to close, a windows box appears and i have to click that to close the epson window.
I might try removing all the epson soft ware reloading and see if that works, but with my luck the printer wont work at all.
Under the EPSON advanced tab it just has PHOTO or PHOTO RPM (MAX DPI)it does not have any numbers. Even if i just use the epson boxes with none of the Photo Elements options it still only prints AT 720dpi.
Dave
Dave
Posted 28/01/2012 - 21:43
i print loading the picture into elements and then >file>print and a window opens to adjust all the settings. i have stylus photo px650 and r1800 they give 360 when i select premium semigloss paper and this is perfectly fine, they select 720 when plain paper is the option. i know when doing some prints at college for public exhibition they were all done on A3 at 300dpi and they were great. hope this helps
Posted 28/01/2012 - 21:55
Thanks REDBUSA99i print loading the picture into elements and then >file>print and a window opens to adjust all the settings. i have stylus photo px650 and r1800 they give 360 when i select premium semigloss paper and this is perfectly fine, they select 720 when plain paper is the option. i know when doing some prints at college for public exhibition they were all done on A3 at 300dpi and they were great. hope this helps
Seems about what i get.
Dave:::
WIRRAL
Can you print at higher than 720dpi on the above, if so, how.
Can only find 360 or 720 in the menu's. my be thats all it has.
Dave
