DOF
mikew
Posted 24/02/2009 - 18:14 Link
I'm getting more and more puzzled about DOF. I have just bought a 70 LTD and very nice it is too, no complaints there but I took a rather dull shot of which a 100% crop is as below.
What I don't get is
70 mm lens at F2.8
The focus was on the bricks
The sign is out of focus and it's a street sign mounted on the standard 2" tube being another 2" from the wall. Surely at over 6 feet (as I recall 8 feet) away the sign should be sharper according to DOF tables?
Or, as is usually the case have I misunderstood something?
Posted 24/02/2009 - 18:20 Link
Telephoto lens. Open aperture. Close distance. All this equates to shallow DOF, which is clearly shown in your image.
You focused on the bricks and the bricks are sharp.
Anvh
Posted 24/02/2009 - 19:01 Link
Focal length (mm) 70mm
Selected f-stop f/2.8
Subject distance 8 ft
Depth of field
Near limit 7.79 ft
Far limit 8.22 ft
Total 0.44 ft
In front of subject 0.21 ft (49%)
Behind subject 0.22 ft (51%)
Hyperfocal distance 284.4 ft
Circle of confusion 0.02 mm
if you go to 6 feet
Subject distance 6 ft
Depth of field
Near limit 5.88 ft
Far limit 6.12 ft
Total 0.24 ft
In front of subject 0.12 ft (49%)
Behind subject 0.12 ft (51%)
as you can see it's already the half of the DOF so if it was just a little less then 8 feet it's out of focus.
Stefan
K10D, K5
AF-540FGZ
shim
Posted 24/02/2009 - 19:08 Link
Use this online DOF Calculator
http://www.dofmaster.com/dofjs.html
shim
mikew
Posted 24/02/2009 - 19:17 Link
So basically you guys are saying I'm an optimist and that DOF tables reflect in the image?
Anvh
Posted 24/02/2009 - 19:36 Link
it's really on the edge of the DOF so it might be a little back focused maybe since the wood on the back is still fairly sharp.
Stefan
K10D, K5
AF-540FGZ
womble
Posted 24/02/2009 - 22:37 Link
Assuming DOFMaster's numbers quoted by Anvh are right, the DOF for 70mm at f/2.8 and 8 feet is +/- 2.4 inches approximately. You guestimated the sign to be 4 inches from the wall and so it would be a little out of focus.
Interestingly, the figures for the 70mm at f/2.8 are the same for 50mm at f/1.4.
Apart from the DOF issue, how are you finding the lens?
Best wishes, Kris.
mikew
Posted 25/02/2009 - 07:20 Link
Kris I guess I didn't convert the DOF figures right when I used the tables from an on line calculator. I used to know all these things years ago!
I have barely used the 70 really but so far I like it. It's what a lens should be. Compact, light, easy to use, it's sharp, the colours are good and overall as you'd expect it seems a good lens. How much better than the Tamron 17-50 which is my usual walkabout I can't say yet. But I do like the fact I can have the 70 on the body, the 35 in one pocket and now thanks to Clarky the 21 Ltd in the other pocket. No bags!
It is beautifully made and I love the cap and hood which I know irritates some people. And from SRS it seems cheap really.
womble
Posted 02/03/2009 - 19:17 Link
I saw the 70mm Ltd at SRS last Saturday. I had no idea it was that tiny. Stunning bit of design.
K.
mikew
Posted 02/03/2009 - 20:13 Link
I am certainly enjoying my three primes as they are so very compact. I have the 21 ltd, the 70 ltd which is as you say very compact - did you see how the hood pulls out and it's still compact? I am still struggling to get the hang of focussing in some situations. The final lens is the 35mm FA which is not so small but is F2.
No more bag for me. Just one on the camera and one in each pocket so holidays will be much more pleasant. Well I hope it works that way.
womble
Posted 02/03/2009 - 20:22 Link
Sounds like a nice solution. If there was an MX-sized Pentax dSLR I would be tempted to go down that route too, although I am infamous for carrying big bags of stuff (not just camera equipment).
I chose the 43mm Ltd because I want to be able to use them on my film cameras too. I'll have to win the lottery before I can get the 31mm and 77mm Ltds.
Cheers, Kris.
mikew
Posted 02/03/2009 - 21:30 Link
Quite. I looked at the full frame ltds and quickly realised they were out of my league. I only got the 70 as a reward for a very, very hard month's work and the 21 because that devil Clarky offered such a tempting deal!
I find the 21 quite wide but pleasant to use and I'm sure when the better weather comes that's the one that will live on the body. I've put a recent 21 shot into the Your Photos bit (well I will have done is two or three minutes).
