Disable Flash
karlh
Posted 01/01/2009 - 21:50 Link
I have set the flash 'on' on my K20D. But cannot find anywhere instructions how to turn it 'off'.. any help, please?
polchraine
Posted 01/01/2009 - 21:53 Link
What do you mean by "ON". Surely if the flash is retracted, it will not operate.
hefty1
Posted 01/01/2009 - 22:34 Link
Just push the flash back down - the button on the side just releases a catch to let it spring up. When it's up the camera selects when to use it; when it's down it's off.
Joining the Q
pentaxian450
Posted 01/01/2009 - 23:10 Link
That only works in "green" mode. In all other modes, if it is up, it will fire.
Clarky
Posted 01/01/2009 - 23:18 Link
I just unscrewed the bulb
Camera:|K-7|
karlh
Posted 01/01/2009 - 23:20 Link
Thanks, guys....so, as pentaxian450 says, if the camera is in a different more from 'green' and I don't want to use the flash, I should make sure that it is retracted (shut).
Mannesty
Posted 01/01/2009 - 23:32 Link
Karlh, it's only January 1st, not April. It doesn't matter what mode the camera is set to if the flash is retracted, it will not fire.
Put very simply, if you don't want to use the onboard flash, make sure it's down.
