Digital CD storage question
Some CD burner software have "Close Disk" option defaulted after writing. This means that anything you write on it will "close" the CD from any more writing. You must change this option to allow future writing into the same CD-R.
Which CD burner are you using, btw?
If you use Nero version 5.??, the default is to allow further writing into the same CD.
Hope that helps.
http://www.pbase.com/santyluib/first_istd_sample_photos
"It's only a Pentax!"
Yes, I have used Adaptec Easy CD creator before and I think it defaults to "Close Disk" or "Close Session?" (something like that) when burning a CD.
I had this similar problem like yours the first time I used the software, until I found this option and disabled it.
so my advice as Tony Blair says... (THE Tony Blair??) is to save 'em on hard disc, and when you have enough, burn em.
24 years
