Digital Camera to Accept M42 Lenses?
However, the overhang on the pentaprism housing (on the *ist D - the other bodies may be different) reduces the headroom above the auto/manual switch on the lens, so if you have big fingers this may be a problem.
George
Off to eBay...
Cheers.....
OK, focusing would have to be done wide open, then the aperture just turned to whatever you wanted and then the camera would set the shutter speed. That would be easier than using the stop down lever for a bayonet lens, wouldn't it?
fully manual screw lenses (or those with an auto/manual switch) can indeed be used in aperture priority mode in this way. This can be very handy, depending on the available light.
http://www.siblog.co.uk/
http://www.siblingmedia.com/
1 Select Av mode
2 Select aperture (on the lens!)
3 Switch to Auto (on the lens)
4 Compose and focus
5 Switch to Manual (on the lens)
6 Shoot.
Repeat steps 3 til 6 until you fill the card or run out of ideas.
Of course, with enough light, or if you want a wide aperture, you can omit steps 3 and 5.
Assuming I don't have any screw mount bodies, do I fit one adapter per M42 lens, and leave it on it. Or is only one adapter fitted to the body, and when switching M42's, unscrew and refit the next M42 lens?
When you have finished with the adapter, depress a small spring in the adapter and carefully rotate and remove it from the body.
This started as one of my first questions on this wonderful forum, and it's really spooky to be coming back after all these months with input.
As I move into K mount camera bodies, and as I wait for my first real K mount lens to arrive (Just won an SMC Pentax A f4 35 - 70 Zoom on eBay), I've been using my collection of M42 lenses on a K Mount Super Program with an adapter.
I've found that the thickness of the adapter flange (mine's about 3/64" acts like a very short extension tube. This make a huge difference in focusing beyond about 5 feet for my prime lenses. The only lens I can get away with at infinity is my trusty old 500mm Russian mirror lens - which has no fixed infinity point.
Now, the flange extension sure helps you focus CLOSER to your subject.
So far, when shooting beyond 5 feet, I've closed the lens down as much as I possibly can, and hope the greater Depth of Field will compensate.
We'll see. The first films should be developed by tomorrow.
Cheers All!
They are less than £15 new, and are still available from your dealer.
No end to what can be learned here.
Thanks John!
I KNEW there had to be a better way!
Well off to - back to - eBay.
24 years
I have managed to acquire a nice collection of Takumar and SMC screw mount lenses along with some beautiful Spotmatic bodies.
With the inevitable reduction in the availability of 35MM film/prints/processing etc, will there be a future for my lenses - ie: a Digital SLR that will accept them? (I'd keep the bodies as a collector).
As my lenses are all fixed length, manual focus and pretty much manual apature, I wouldn't expect to use them in any "coupled" manner.
As you've probably gleaned, I know absolutely nothing about digital technology - so feel free to ignore this query if I'm totally out to lunch.
