Difference between m and a
Posted 04/11/2014 - 07:18
Is it aperture priority?
Posted 04/11/2014 - 08:09
Both are superb lenses (assuming you're talking about the f/1.7 versions), they have the same optics. The A version communicates the aperture to the camera when the aperture ring is in the A position, which means all exposure modes can be used. The M version can't do this so you will need to use manual mode and use the green button (or guess) to get the exposure right. The M version is better built though - all metal as opposed to the plastic of the A.
If you're just starting to use manual lenses, remember to enter the menu and set the camera to allow the use of lenses without an A mode. If you don't do this then old manual lenses will not work.
Good luck with whichever you choose.
Posted 04/11/2014 - 08:45
There are no electronic contacts on the M series lenses, and no "A" on the aperture ring. This means they cannot do some programs such as Tv and will only work in M and Av modes. Stop down will also have to be manually set.
The A series will work with almost everything, apart from not being autofocus of course. Just set the aperture ring to "A" and let the camera control things.
Posted 04/11/2014 - 08:52
Ok. Clean as crystal. Thanks everyone
Posted 04/11/2014 - 08:55
You're really restricted to M mode only with the original smc lenses. Even in Av mode, as there's no contact electronic contact the camera does not' know' what aperture is set on the lens and cannot control the lens aperture. As said above, you set the aperture on the lens first, point at where you want to meter primarily then press the green button ... The lens stops down and the meter reads the light and sets an appropriate shutter speed. You can then change the speed in order to make it darker or brighter.
It's really two extra steps in practice ... You get quick with practice, but the A type lenses eliminate these steps, which can be more convenient.
Posted 04/11/2014 - 10:13
Very important..... The 'A' lens details are recorded in the
Exif data along with the aperture + speed used if the lens
is set on A.
PhotoMe shows ...
smc PENTAX-A 50mm f/1.7 or 135mm f/1.8
The 'M' lens just shows M Lens and the speed. No aperture.
is set on A.
PhotoMe shows ...
Posted 04/11/2014 - 11:36
If this link is permitted, you can read all about them here:
http://www.pentaxforums.com/lensreviews/
Cheers.
Philip
Cheers.
Philip
Posted 04/11/2014 - 20:57
Thanks everyone for your help. By the way, anyone selling a 50mm by any chance?
Posted 05/11/2014 - 08:01
There's a K 55mm f/2 for sale here:
https://www.pentaxuser.com/forum/topic/fs--pentax-smc-k-55mm-f2-0-50667/p-0#comm543412
The K will work in the same way as the M. It's a very good lens and I'd say this is a very good price for it.
Posted 05/11/2014 - 08:32
I've got about 4 Pentax-A 50mm f/1.7's mostly on bodies.
All of them are in excellent condition and if you want one
I could sort out a good one for £39 posted. Both caps included
but they won't be Pentax originals.
Let me know by PM if interested.
Posted 05/11/2014 - 14:31
Thanks for the posts guys. I am currently bidding for 1 on eBay at the moment. If I am not successful I will get back to you
Posted 05/11/2014 - 14:52
The way I've worded that could be confusing The £39 is just for a lens not lensI've got about 4 Pentax-A 50mm f/1.7's mostly on bodies.
and body. I ran out of body caps so I put lenses on until I get some. One of the bodies
is an MZ-S
Posted 05/11/2014 - 17:47
Just pointing out that these limitations only apply to bodies with crippled mounts (all of the DSLRs and some of the MZ series film cameras). I usually use HyperManual so I don't really notice the extra step. Otherwise 'K' & 'M' lenses work fine in M and Av on film bodies. A future FF with non-crippled mount would be very interesting!You're really restricted to M mode only with the original smc lenses. Even in Av mode, as there's no contact electronic contact the camera does not' know' what aperture is set on the lens and cannot control the lens aperture. As said above, you set the aperture on the lens first, point at where you want to meter primarily then press the green button ... The lens stops down and the meter reads the light and sets an appropriate shutter speed. You can then change the speed in order to make it darker or brighter.
When using my K-5, the only real drawback when using M lenses is that because you need to use Manual mode, you lose the horizontal spirit level in the finder (it becomes the exposure +/- indicator).
John.
