DFA100 WR good or not?
Posted 12/03/2010 - 06:00
As far as I know, the DFA100 f2.8 WR is exactly the same lens formula as the previous DFA100 f2.8 macro which has superb sharpness and excellent bokeh. I would say that the bokeh should be the same.
Cameras:K-7/K20D/*ist D/K10D
Lenses:DA14 f2.8, A16 f2.8, FA20 f2.8, FA31 f1.8, DA35 f2.8 macro, FA43 f1.9, FA50 f1.4, A50 f1.4, A50 f1.2, FA50 f2.8 macro, DA*55 f1.4, FA77 f1.8, DFA100 f2.8 macro, A100 f2.8, DA*300 f4, FA*300 f4.5, DA10-17 FE, DA12-24 f4, DA*16-50 f2.8, DA17-70 f4, FA*28-70 f2.8, DA*50-135 f2.8, DA*60-250 f4, FA*80-200 f2.8.
Flashes:AF540FGZ, AF360FGZ
Posted 12/03/2010 - 08:14
I thought the WR lens had a rounder diaphragm. This would affect the rendering of the out of focus areas.
Posted 12/03/2010 - 10:03
Would really like to know if anyone on here has one, and what their experiences are with it, as I want one!
Having had a quick play with one at SRS and comparing it to my FA 100 Macro, the fact that it seemed half the size, felt great, has weather sealing and works better with the macro flash really has me sold!
The only thing I am uncertain of is the image quality. Will I be getting a performance gain or hit, and if so will I even be able to notice it? It will be bought soon, but would like to hear some first hand experiences first if possible.
Posted 12/03/2010 - 12:36
Thank you guys
The light distribution in the disk so bokeh is still the same because it uses the same lens formula.
And when you use the lens wide open it doesn't use the aperture blades at all and both lenses are round so precisely the same photos.
I had my hopes it would a bit more of an effect but by the looks of it it's only the build quality that makes me want it the most over the DFA100 I've now, the rounded blades are a plus but not something I would buy this lens for.
So how is the build quality?
Yeah that's true but the effect is minimum form all the pictures I gathered, only when you can see a clear bokeh blob, disc of confusion is a better word then you see it are rounded blades for the rest you can't tell them apart.I thought the WR lens had a rounder diaphragm. This would affect the rendering of the out of focus areas.
Posted 12/03/2010 - 13:04
I have seen side by side comparisons on another forum and there is a visible difference in bokeh between them, especially with small diameter bright objects in the OOF area.
Posted 12/03/2010 - 13:27
Mike-P wrote:
Why does it work better with the macro flash?
I'd imagine that in order to be WR, the front element must not extend during focusing. Just speculating though as I own the non-WR version of this lens (and don't own a ringflash).
Posted 12/03/2010 - 13:31
With the FA lens, you screw a ring on to the front element where a filter would go, so that the ring flash has something to attach to, so when you are focussing the ring flash moves in and out at the same time. It feels like a strain on autofocus!Why does it work better with the macro flash?
With the DFA you attach what looks more like a lens hood onto the actual body of the lens, then the ring flash attaches to that. When focussing, the lens moves freely, whilst the flash stays in a fixed position.
Hope I've explained that well enough!
edit: just seen the above post, and yes, the front element does extend whilst focussing on the WR lens.
Posted 12/03/2010 - 13:44
The DFA WR and non WR are both just as suited for the pentax ring flash, it use the hood bayonet with those lenses I believe.
The bright discs only look more round nothing more nothing less, when you can't make out a clear disc the bokeh is the same.
Oggy that not true, you only see it with the bright dics, here see for yourself.I have seen side by side comparisons on another forum and there is a visible difference in bokeh between them, especially with small diameter bright objects in the OOF area.
Posted 12/03/2010 - 15:07
We have the FA and D-FA 100mm macro lenses, and in terms of quality there's nothing to choose between them. The limiting factor is our technique.
Posted 12/03/2010 - 15:32
Indeed John but it's never a sin to have something you like.
I'm sure you could appreciate the build quality of the WR lens.
Posted 12/03/2010 - 16:18
I'm sure I could and if I were to be buying new at this moment then that's the one I would go for.
Posted 12/03/2010 - 16:43
It could just be my eyes but in terms of the comparisons above, whilst the out of focus areas appear to be the same, the in focus areas appear to have a bit more of a 3C quality about them in the non-WR pictures.
It's probably my eyes though.
Apparently.
Apparently.
Dordrecht,
the Netherlands
I can still not say if the bokeh is better or not, what do you think?
Has anyone handled the lens, the build quality of the DFA100 isn't super you see so some feedback on that would be great.
K10D, K5
AF-540FGZ
