DFA 70 - 200 foot removal
Posted 03/05/2025 - 19:30
Assume it's the same procedure as the 150-450mm.
Unscrew the knob
Push the knob in
Simultaneously push the whole foot towards the front of the lens and it will come away.
Unscrew the knob
Push the knob in
Posted 04/05/2025 - 09:16
Fab, thanks, will give that a go later today
Chris
Posted 04/05/2025 - 10:52
Spot on, that worked and discovered the issue is with a broken part within the foot
Chris
Posted 04/05/2025 - 11:04
Just ordered a replacement foot only ( collar not needed ) from SRS,
I'd forgotten I'd had their rewards thingy from a previous purchase, prob my K3iii and that reduced the foot replacement cost from £69 to just the postage, special order but should arrive the middle of this month
Thank you SRS
Thank you SRS
Chris
St Austell,
Cornwall
Can anyone advise please how to remove the foot from a DFA 70 - 200, its been loose for a while and I wish to see if it can be tightened up even with the foot screw fully tight.
Any suggestions / advice gratefully received
