DA 55-300 ED
Posted 21/08/2013 - 09:27 - Helpful Comment
Without trying your lens it's hard to say. The descriptions could mean different things to different people.
Why not try another in a shop somewhere and then you'll be able to compare.
Posted 21/08/2013 - 09:35 - Helpful Comment
The zoom is fairly stiff on mine but I like that as there is no 'creep' when using it at an angle. Also the focus ring is as you say easy to turn. I don't mind this either.
However at full zoom there is quite a bit of barrel movement. It does wobble quite a bit. More than I would expect. Is this normal?
6th Year Apprentice Pensioner
Posted 21/08/2013 - 09:38 - Helpful Comment
if it wobbles take it back. Two year warranty if bought from Pro dealer.
Is it taking good sharp photos? That's what matters.
Posted 21/08/2013 - 16:59 - Helpful Comment
They all do. Don't overlook the fact that the length of the lens almost doubles at full zoom, so hardly surprising there's a bit of movement if you flex the lens. However at full zoom there is quite a bit of barrel movement. It does wobble quite a bit. More than I would expect. Is this normal?
Now if it drooped, that'd be a problem!
Posted 22/08/2013 - 07:53
Thanks Gents
Posted 23/08/2013 - 16:27
http://www.dpreview.com/forums/post/27874898
Found some more on this; seems to confirm tight zoom, reviewer tested several.
13 years
Bedfordshire
Zoom seems a little stiff and the focus ring very easy?
