DA*300mm focusing problem again!
Posted 20/01/2015 - 00:07
I have a 16-50mm (over 5 years old), 50-135mm (had at least 4 copies), 60-250mm (4 years old) and 300mm (2 years old) ... I have had the 55mm and 200mm. The only SDM problem I have had is with my current 50-135mm which needed a new motor, but then it would as I bought it at a silly low price because the AF wasn't working.
But then you only tend to hear from the people who have had problems.
Edit: Ooops ... forgot my 17-70mm, still going strong after a couple of years.
Both my Sigma 50-500mm OS lenses (Canon and Pentax mount) have been back to Sigma as has the Canon mount 70-200mm f2.8 OS.
Posted 20/01/2015 - 21:42
I owned a second hand 50-135mm for approx 5 years and apart from the mount snapping and needing a repair by JPS (returned win 10 days) I never had an sdm failure. I also owned the 16-50 for nearly two years again purchased used and never had any issues with that either
My nikon 85mm 1.8 didn't af out the box and was returned to me twice by nikon with no fault found despite not working in my d600 or d7000 eventually they replaced all the af internals and it came back working nearly 10 weeks without that lens.
My sigma 100-300mm f/4 was repaired within two weeks by sigma.
I do use my lenses on a daily basis and wonder how many pentax sdm failures are due to not being regularly used.
Concert photography
Concert photography
Posted 21/01/2015 - 16:07
Neil P mentioned to me about a screw on the mount (well not actually a screw, more a pin with a slotted head) that had got loose on his DA*300. I located it and turned it and it appears to have done the trick with it now focusing both manually and auto. When you turn this it reaches a point where it feels like it is up against a spring and shouldn't be turned further. Of course it might be because it is back in the warm and something has expanded enough for the clutch mechanism to start working again.
Posted 21/01/2015 - 18:56
I think you're describing the shaft for/of the screw drive.
11 years
My Pentax 50-135 has had two completely separate issues, but for now seems to be working quite swell.
Add to that my neighbor who teaches photography at three separate schools. Out of all of the students she's had over the past two years who have had Pentax camera bodies; four of her students have had issues with Pentax SDM lenses.
So out of my entire current Pentax lens collection, which includes all but one of the current Pentax line; the problem seems to limit itself to SDM lenses. They literally do not last half as long as the other types of Pentax lenses; especially the FA's. It's also quite sad to see that Pentax labeled lenses not lasting as long as Sigmas, even Rokinons (ouch)
