DA*300mm focusing problem again!
dcweather
Posted 17/01/2015 - 15:39 Link
Having waited 2 months to get the SDM motor replaced by Pentax for £200 it has now developed another fault after a month back. The AF failed to do anything. Tried cleaning contacts, new battery etc. then realised that MF was just turning round and round without changing the focus at all. Then it will move it a bit, then the AF starts working but MF doesn't. Any ideas what can cause this. It feels like it is not engaging with whatever turns the elements, physically rather than electronically. Any ideas. Obviously I will have to send it back again.
Dave
stu62
Posted 17/01/2015 - 16:36 - Helpful Comment Link
it sounds like a repair malfunction ie the person that repaired irt did not tighten somthing up and it as now come lose
gtis
Posted 17/01/2015 - 16:59 - Helpful Comment Link
Hi dave
If it was repaired byJPS it will come with
A 6 months warranty as my da* 50-135
did when the SDM went on that
cheers Neil
pentax k3
Panasonic Dmc Fz200
Fletcher8
Posted 17/01/2015 - 17:38 - Helpful Comment Link
Sounds like the focus clutch is not working as it should.
Fletcher8.
dcweather
Posted 17/01/2015 - 21:22 Link
gtis wrote:
Hi dave
Unfortunately they couldn't repair it so it went to Johnsons via SRS so I should be ok I think. Very annoying all the same.
sterretje
Posted 18/01/2015 - 06:00 Link
Send it back for warranty repair.
I had my FA31Ltd fixed (lens hood replacement) and after a while it got stuck while focusing; focusing worked fine when pointing camera up or down One screw somewhere came partially loose. Warranty repair on the repair.
I know it's annoying; this obviously happened when I was asked to take photos of a XMAS dinner and I did not bring a lens that could be used as replacement; had to finish it off with the DFA100WR.
Pjy123
Posted 18/01/2015 - 08:28 Link
Hi all. I keep seeing comments on sdm motor failures is this a common problem as I was looking to get a better lens?
Posted 18/01/2015 - 09:09 Link
The SDM problem was really on early batches of the 16-50mm and 50-135mm lenses, but it was solved a long time ago. These things persist on the internet for ever.
There will always be some failures, but that applies to everything man made.
Pjy123
Posted 18/01/2015 - 09:40 Link
Thanks for that John you put my mind at rest.
JohnX
Posted 18/01/2015 - 10:56 Link
dcweather wrote:
gtis wrote:
Hi dave
'Johnsons' is JPS , isn't it?
Posted 18/01/2015 - 14:48 Link
Yes it is.
50mpCMOS
Posted 18/01/2015 - 20:31 Link
[quoteThe SDM problem was really on early batches of the 16-50mm and 50-135mm lenses, but it was solved a long time ago. These things persist on the internet for ever.
There will always be some failures, but that applies to everything man made. ][/quote]But, per ratios of one hundred copies... Those two Pentax lenses are near the top ten in worst lenses ever made. Cannot begin to mention how many of them I've seen fail.
Considering the number of copies sold. It speaks volumes when those two Pentax lens issues also outdo most any lens ever sold by Nikon or Canon.
If one happens to own one of those series of lenses, nothing quite worse than having the need to carry around a second or third lens (because of need and not want)
Posted 18/01/2015 - 20:38 Link
We tend to hear all about failures, but since the problem was tackled we haven't heard a peep on this forum. That's all we can judge by.
I recall Canon actually had to withdraw a lens completely because of various faults.
dcweather
Posted 19/01/2015 - 14:49 Link
I may be getting muddled. SRS sent it to their independent repairer (Had 3 initials but can't remember) who couldn't get the parts so they sent it to the Pentax repairer which I think was Johnsons.
Anyway, after a suggestion from Neil P I tried turning a slotted pin on the mount (not an actual screw) which seems to end with a spring like feel. It now seems to be engaging. It could of course be due to expansion in the relatively warm interior which has done enough to get it working. I hate intermittent faults because if i send it back and they can't replicate it you don't know where you are.
Dave
JohnX
Posted 19/01/2015 - 14:59 Link
I'm intrigued. Spill the beans
The only 50-135 I've ever seen is mine, and it works great. Never seen a 16-50.
