DA 18-55 WR "better" on K-5 than K-7?
Posted 17/12/2011 - 01:25
With the improved sensor on the K5, one could argue that all lenses work better on it!
John
John
Posted 17/12/2011 - 07:56
He hopefully will see his name mentioned and answer this for us.
Posted 17/12/2011 - 08:20
Its almost certainly to do with lens and camera tolerances. QC allows a small range of error around the "ideal".
Say you allow a plus or minus 2% error in focus to achieve acceptable results. If your copy of a lens is at the -2% end of the range and your camera is at the +2% end of the scale then you now have a 4% error.
If the errors on the camera and lens are both at the same point of tolerence then you get a "perfect" result. Both don't have to be at the perfect 0% error point . If they are both at -2% that is also a "perfect" result.
So it is likely the camera to lens match is better on that particular lens and that particular K5.
.........all the gear, no idea!
Me super, MX, LX, K5,DA 18-55WR, DA 17-70, DA 55-300, DA40 Ltd, FA50 1.4, Samsung D-Xenon 12-24,Samsung 100mm macro M50 1.7(x3), M28 3.5, M35 2.8, M100macro f4, M135 3.5(+others)
Posted 17/12/2011 - 10:40
Hi Guys, I have being using a Pentax 18-55wr on my K20D for the last couple of years with no problem and being getting some very good results, now i have upgraded to a K5 and i would say that the 18-55wr struggles to keep up with the sensor but my sigma 17-70 is fine on both. Needing a weather resistant lens i have bought a Pentax 18-135wr and i have to say the image quality is fantastic, not sure what happened with the Photozone test but i would ignore it.
Regards Robin.
http://exevalleyphotography.co.uk/
Regards Robin.
Posted 17/12/2011 - 11:02
John
It's probably that the improved ISO results allow 'so-so' lenses like the kit lens to be used at their optimal aperture (f8?) without using slow shutter speeds (and introducing camera shake).
John
Posted 17/12/2011 - 11:24
nimasmi wrote:
Sounds like the type of thing an ebay seller would say
obione wrote:
18-55 WR works far better on the k5
Posted 17/12/2011 - 11:27
I've just bought a used 18-55WR as a backup to my DA17-70, haven't used it so far and considering how good the DA17-70 probably rarely will but this thread has just prompted me into at least doing a couple of comparision shots!!
Simon
Simon
Find me on Google+ link
Posted 05/02/2012 - 17:22
You may get different results using two different K7's or two K5's, not just a K7 & K5....
Posted 05/02/2012 - 19:53
Posted 06/02/2012 - 00:14
I can't answer the question but I have to say that I've had some fantastic results with the kit lens for landscape photography and will continue to use it for this even though I also have a DA 16-45mm which is also fantastic.
