DA 17 - 70mm focus issues
Posted 04/03/2019 - 22:00
This issue is common on the DA 17-70, they have inherent design faults which cause the symptoms you are describing. It's not a question of whether you will have focus issues with this lens, it's a question of when.
The DA 17-70 is a very good lens when working correctly, but it's too prone to fail and I would steer clear of buying another one and would go for a more reliable alternative instead. The Sigma 17-70's are very good, both the current and previous versions. Sorry if this sounds a bit negative towards the Pentax lens, but I'm just giving an opinion based on previous ownership and also from other people I know that have had issues with the DA 17-70.
Posted 05/03/2019 - 14:31
I was about to buy one when my 16-50 first failed, it was in Jessops (Mk1) in Richmond. Before passing the money I asked to check it on a camera and it failed to work....
what blights the lens even further that it's SDM only, no option for screw drive...
AKA Welshwizard/PWynneJ
13 years
Nottingham
