DA vs. DAL
Posted 04/05/2010 - 19:49
I haven't tried the 55-300mm but I do have the DA L 18-55mm. The plastic mount is no trouble at all, I've taken that lens off and put it back on more times than I can count with no sign of premature wear.
As I understand it the DA L lenses are identical to the later non-L versions in optical terms, so I'd expect similar performance.
Posted 04/05/2010 - 19:59
Optics are the same the only difference is that the DA-L versions doesn't have a metal-mount, lens hood and quick-shift.
The plastic mount doesn't seem to wear much, there are older lenses with a plastic mount which still seems to do fine.
Posted 04/05/2010 - 21:20
Although the plastic mounts seem fine, I still like a metal mount. In the very long term I would expect it to be more durable.
Wiltshire
