DA* 55mm SDM
Posted 11/05/2009 - 16:21
Your best bet is to go to a dealer and try it and see.
Failing that, save some money and buy the FA version instead?
Posted 11/05/2009 - 16:30
The one I tried appeard to be back focusing on my K10D @ F1.4, then again, so did the Sigma 30mm F1.4!
I agree with John, the FA 1.4 might be a better option. Then if you were a K20D owner, you could change focussing for each lens independently!
Flash: Metz 58, Metz 48
Posted 11/05/2009 - 16:44
Thanks all. I'm unable to drive at the moment due to medical reasons, so visiting shops is not very easy. The FA 1.4 does seem a bit of a no-brainer, and I suppose it's time to start saving for the new body anyway...
Posted 11/05/2009 - 16:53
Only used it a little since I've had it, but it definately seems sharper than the FA version that I had. Still it should be with the price difference!
Works fine with the 1.4 Tamron TC with SDM contacts, but then I wouldn't do that as I can just put the 77mm Ltd on instead!
Posted 11/05/2009 - 17:06
TonyM wrote:
I'm unable to drive at the moment due to medical reasons, ............. and I suppose it's time to start saving for the new body anyway...
I feel the same way mate
Posted 11/05/2009 - 19:32
IMO buying a very high quality lens and then lowering the IQ by using it with a converter seems like defeating the object...
Posted 11/05/2009 - 20:18
Yes, I agree, I have understood why these converters are so popular. I had one 30 odd years ago and basically chucked it away. They must always degrade the quality of the lens and slow it by stops I think.
Still each to his own. I think I'd rather have the 50-135 lens that's about at the moment.
Posted 11/05/2009 - 23:23
Agreed with Mike there and also about the FA50.
The bokeh of the FA50 and The DA*55 seems very much the same although the DA*55 is sharper and does that across the frame. So if sherpnees is really needed get the DA* if not like portrait for example the FA will be a cheaper solution.
You can of course get the FA50 and maybe a 100mm macro...
The FA50 + Tamron 90mm macro will cost you £95 more the only the DA*55 then also comes a TC wich needs to have SDM/PZ connectio do you want to have autofocus so the difference will be less or you might even be cheaper.
The DA*50-135 is also a wonderfull lens, I regret not buying it sooner
Surrey
