Curved sensor
stu62
Posted 07/01/2018 - 18:03 Link
So the rumour as it that Ricoh are bringing out a 36mp curved sensor
If true what would the advantage of the curved sensor and will it make it's way on to the forth coming Pentax cameras
RobL
Posted 07/01/2018 - 20:33 Link
I think this is a Sony development, The idea being that the distance from the lens to the edge of the sensor is the same as to the centre, so eliminating distortion. Don’t know how that would work with the various Pentax features which move the sensor around like SR and pixel shift though.
Posted 07/01/2018 - 22:04 Link
It's been done before with cameras with curved pressure plates for film. The idea was that it compensated for cheap lenses that were mass produced. I'm sure in a modern context that won't be the reason though!
McBrian
Posted 08/01/2018 - 05:39 Link
When talking about curved sensors I presume it is actually spherical, a one plane curved sensor would be a lens makers nightmare.
Brian.
RobL
Posted 08/01/2018 - 08:25 Link
Quite so, and would it need to change with different lenses and focal lengths? The physics is way beyond me. And, when exported to a flat format live view, screen or print does the image not simply revert to what would have been recorded on a flat sensor?
Gajan
Posted 08/01/2018 - 09:37 Link
They may do something opposite (or inverse) of what lens correction does?
Best Regards,
Gajan
Flickr : link
Pentax K-1, D-FA 28-105mm, FA 77mm, D FA 100mm Macro
Pentax K-5, 18-135 mm, 55-300mm
Pentax K100D Super, 18-55mm
Posted 08/01/2018 - 10:16 Link
Lenses project a curved image onto a flat surface, and good ones do it very well, managing to keep centre and edges in sharp focus at the same time. This is especially true of macro lenses, which are often used to make flat copies.
A cheap lens will show field curvature and at wider apertures the edges may not be in focus when the centre is. This is easy enough to discover using a newspaper as a target. One solution is to curve the film/sensor so that everything is in focus.
The other thing is deliberate field curvature and Minolta made a VC lens where the amount of curvature could be dialled in. This made semi-circular groups of people easy to photograph without distortion and whilst keeping them all sharp. It's not been a mainstream idea that's caught on in any great way, except probably within the secrets inside inexpensive compact cameras.
petrochemist
Posted 08/01/2018 - 12:16 Link
In case anyone else tries Googling for more detail they were called 'VFC' in the case of the 24mm (VC brings loads of Tamron stabilized 'vibration control' hits).
They also made a 35mm shift lens with variable field curvature.
While they look interesting but not something I'd really have a use for, especially given the price they go for!
Edited by petrochemist: 08/01/2018 - 12:41
Posted 08/01/2018 - 12:56 Link
Many thanks for the correction!
Gajan
Posted 08/01/2018 - 17:37 Link
Interesting stuff!
Best Regards,
Gajan
Flickr : link
Mag07
Posted 08/01/2018 - 19:10 Link
Think the rumor has been discarded as fake. At least in regards to the GR.
McBrian
Posted 08/01/2018 - 22:00 Link
Varible field curvature lenses are an entirely different concept to curved sensor.
VFC lenses manipulate circular lens groups to modify the peripheral field curvature projected on to a FLAT plane, this is a very different concept to projecting on to a curved plane. I can see it possibly working for a sperical sensor but I don't think we will ever see it in consumer/everyday professional gear.
Brian.
Edited by McBrian: 08/01/2018 - 22:00
johnha
Posted 09/01/2018 - 03:11 Link
Sadly it's not likely to be about the results, but the fact it's curved (i.e. about to become trendy). Curved Tv screens are dreadful unless you're positioned perfectly. John's right, film cameras with rubbish plastic lenses used a curved pressure plate to make up for the lens aberrations. However, lens design has tanked over the years, based on the premise that your image processing software has a lens profile to correct for the lens used - the designers don't seem to need to bother getting the best from the 'glass' (much of which is plastic of varying quality).
