CS3 Bridge Metadata Templates
Posted 05/02/2008 - 21:30
Hi Lilly,
I just checked it on my pc. If i open a photo in bridge and i go to the tab
iptc core i see that the fields are all editible.(small pencil sign)
But........,As my Raw converter is L.R. and in that program i submit the metadata, i reckon that bridge has no problems to read it. Both beeing Adobe products. Did you put in the metadata at the raw processing stage?
Under Edit-------->Preferences you find a lot of info about the possibilities and choices.
Hope it helps,
Martin
Hope it helps,
Martin
Posted 06/02/2008 - 11:52
Thanks for replying, but I can't see why I should have to edit that field in Lightroom to transfer it across to Bridge.
I did apply the metadata info to the file at its RAW stage when I import from memory card.
I am aware of setting the preferences and I have discovered the only way I can edit this particular field of 'copyright status' is to:
File
Info
Description
and set copyright status to copyright instead of the default of 'unknown'
I can of course do this as a block change to a folder
but I think is real strange that I should have to do this in this extra way through File etc..
rather than like the rest of the editable fields that have a little pen beside them.
Seems it is just one of those things that Adobe have done for reasons best known to themselves.
Cheers anyway
Lilly
File
Info
Description
Cheers anyway
Lilly
Duchy of Cornwall
Any ideas?
Lilly
BLOG
FLICKR
