CPL for Pentax 18-135mm
dave_walton
Posted 04/09/2019 - 17:25 Link
Can anybody recommend a reasonably priced Circular Polarising Filter for the Pentax 18-135mm WR it is a 62mm Thread I believe.
mr.mellow
Posted 04/09/2019 - 18:27 Link
Have a look at the Hoya Pro 1 Digital filter.
The older I get the faster I was.
Dave
K-3 II, K10D, DA16-85, DA*50-135, DA12-24, DA18-55, DA 50, Sigma EX DG 70mm Macro, Sigma 70-300mm, Sigma DG 120-400mm APO HSM.
Metz 58 AF-1.
My Flickr link
stub
Posted 04/09/2019 - 19:09 Link
I would recommend you buy a larger CPL filter and a step down ring.. As quite a few Pentax lenses now have a larger filter size,,
Stuart..
Mannesty
Posted 04/09/2019 - 19:37 Link
https://www.amazon.co.uk/Hoya-Pro-1-Digital-Screw-Filter/dp/B000KZ9916/ref=sr_1_3?keywords=hoya+62mm&qid=1567622238&s=gateway&sr=8-3
Mike-P
Posted 04/09/2019 - 19:44 Link
That's a UV, not a CPL.
Mannesty
Posted 04/09/2019 - 20:34 Link
Oops. Try this one https://www.amazon.co.uk/Hoya-Digital-Circular-Polarizing-Filter/dp/B000KL7K0M/r...=sr_1_10?keywords=hoya+62mm&qid=1567625625&s=gateway&sr=8-10
JAK
Posted 04/09/2019 - 21:24 Link
Try a camera shop somewhere and see if they have something suitable in their clearance or S/H bin.
You don't actually need the circular variety for Pentax cameras though if shared with other brands you might do.
This might be worth a punt: https://www.ebay.co.uk/itm/62mm-Genuine-HOYA-Circular-Polarizer-Filter-CIR-PL-CP...
Edited by JAK: 04/09/2019 - 21:25
MrB
Posted 05/09/2019 - 09:12 Link
I bought a new one this summer from a local company - SRB Photographic in Dunstable. It is well-built from anodised aluminium and multi-coated glass, and its movement is smooth and suitably damped. Not having used one before, its effect of deepening the blue of the sky was pleasantly surprising. This is Castle Pomeroy, a ruined castle in Devon:
SRB 62mm Circular Polariser
Philip
Jonathan-Mac
Posted 05/09/2019 - 09:21 Link
The problem with this is that the lens hood will probably no longer fit over the large filter and stepping rings.
I have a 49mm Marumi CPL which is superb - I use it on my DA Limited lenses with no visible image degradation. I think mine is the smaller version of this one (Super DHG): https://www.amazon.co.uk/Marumi-Super-circular-polarising-Filter/dp/B001F7BFMY/r...=sr_1_6?keywords=62mm+marumi&qid=1567671574&s=gateway&sr=8-6
But there's a cheaper "slim" Marumi CPL here which has excellent reviews (though not many of them): https://www.amazon.co.uk/Marumi-Slim-62mm-Circular-Filter/dp/B00NXT41VO/ref=sr_1_2?keywords=62mm+marumi&qid=1567671574&s=gateway&sr=8-2
swarf
Posted 05/09/2019 - 10:05 Link
I also use the Hoya Pro 1 and I'm very pleased with the performance, although I expect that any of the premium brands would work just as well. However, in my opinion it's just not worth while buying a cheap 'knock off' version.
The point about the benefit buying a larger version and using step-up/down rings is a good one, but don't forget to also buy a lens cap of the same size. But note Jonathan's point about the lens hood not fitting - that can be a real pain.
Phil
My Flikr Page link
barkin
Posted 05/09/2019 - 11:34 Link
Jonathan-Mac
Posted 06/09/2019 - 10:23 Link
I have a cheap CPL (67mm I think) I used on the first day in San Francisco a few years ago on my Tamron 17-50mm. The pictures were awful: poor contrast, dull colours and a slight drop in sharpness (though that could have been my perception due to the first two issues I mentioned). I took it off and pictures were much better.
barkin
Posted 06/09/2019 - 11:30 Link
The most noticable thing I've seen with cheap ones is that they can give an unpleasant colour cast.
Unfortunately SRS weren't discounting the one I mentioned above at the time I got mine...
PeterKR
Posted 06/09/2019 - 12:09 Link
Spurred on by this info I clicked on the link to find they are currently on offer !
I bought both a 62 and a 49 at that price !
Thanks for the link
bychan
Posted 08/09/2019 - 15:02 Link
With the non-slim filters, chances are that you will notice vignetting at the widest focal ranges.
It was for this reason why I always purchase the slim models (dearer but better).
To date I have a Marumi Super 72mm and a Hoya Pro 82mm, equally as good.
K5IIs, Sigma 10-20, Pentax DA 16-85, Pentax DA 55-300, Pentax 70 Ltd, Metz 44 AF-2.
Flickr: https://www.flickr.com/photos/ambott/
