Correct size for reproducing representative technical viewpoint images.
Posted 11/04/2016 - 11:42 - Helpful Comment
you are testing my very old maths brain here....
But I think it's down to Tangents where the Tan of a right angle triangle = Opposite side/ adjacent side.
here the angle is 19.05(38.2/2) and the adjacent side is 300mm.
Tan for 19.05=0.3452 so I've got x =300x0.3452=103.59
double that for the total angle of view, images needs to be 207.18mm wide
Barrie - Too Old To Die Young
Posted 11/04/2016 - 12:23
Now I know why I should have tried harder at maths all those years ago! Great stuff
Posted 11/04/2016 - 12:35
Posted 11/04/2016 - 12:48
I'm not with why you would do the pano then crop to the same size as you could achieve with a single shot?
If you have shot in portrait format and use 207.18 as the height of the image you could make it as wide as the Pano or paper would allow.
Posted 11/04/2016 - 14:16
You don't need angle of view and tans. It's just similar triangles.
300/35 = 8.57 magnification factor so for 23.7 sensor it's
8.57 x 23.7 = 203.1mm
Alternative use 297mm A4 paper = 297/23.7 = 12.53x mag.
View at 12.53 x 35mm = 438.6mm
Posted 11/04/2016 - 15:32
There are firms that do this for a living using the digitised drawings to accurately paste into a street view or landscape. I would recommend getting a couple of quotes as otherwise you could be at risk of misrepresentation if you get it wrong - google 'architectural visualisation'.
Posted 13/04/2016 - 21:35
I'm a landscape architect by the way! Barrie's advice tallies with the landscape institute guidance I've dug out so thanks again Barrie!
I'm not convinced that landscape and architectural practices do size their images in a representative way as a matter of routine, from what I see it's generally a case of making it fit in the page
Nottingham
I guess the simple question to ask is, what size does the image need to be displayed on the page to represent the view faithfully - at a viewing distance of 300mm? To further clarify, imagine the image was being printed on transparent paper and you held it in front of your face at a distance of 300mm in the spot the picture was taken - the image and the view seen through the paper should match.
Is there any way of calculating this?
