Contrast Control numbers
Posted 04/02/2010 - 00:00
I believe the first number refers to the Master and the second number refers to the Slave. I've only got one P-TTL flash though so I've never confirmed that 100%.
Joining the Q
Posted 04/02/2010 - 19:15
Is the pop-up on the K10D not P-TTL, I was hoping I could use my 360FGZ wirelessly off camera with the pop-up as master and use contrast control, am I right in thinking that?
Posted 04/02/2010 - 19:28
From what I have read, contrast control, (where the output of two or more flashes is controlled) is only available when the flash unit(s) are hard wired with off camera flash cords etc
Retired at last - now all that time for photography - you would think: wink:
Posted 04/02/2010 - 20:04
The manual is not very clear about that if you read about the restrictions of the contrast flash mode at page 74 it says you can use the build-in flash.From what I have read, contrast control, (where the output of two or more flashes is controlled) is only available when the flash unit(s) are hard wired with off camera flash cords etc
This makes of course sense if you can use the build-in flash as master in P-TTL mode you need some control over how the flash power is distributed between the flash-units that are used or do I say something strange here?
Posted 05/02/2010 - 10:34
Sounds like it's a bit of a 'Black Art' this flash photography
Posted 05/02/2010 - 12:24
Contrast control with the pop-up flash works only with a cord, but you can get the same effect by varying the flashes output with flash compensation.
Posted 05/02/2010 - 12:28
Found this link: http://pttl.mattdm.org/feature:contrast-control-sync
You know, the more I read this, the more I'm confused
Think I'll have to go and experiment!
EDIT: and here http://www.pentaxforums.com/forums/camera-studio-accessories/58723-wireless-cont...
what's contrast control?
It's where you have multiple flash guns all firing. You probably don't want them all at the same level - so contrast control allows you to set the ratio of each flash to give some contrast to the scene (rather than being totally flat and lifeless).what's contrast control?
20 years
