Confused again!
Posted 15/02/2010 - 23:11 - Helpful Comment
No, 28-300mm is always 28-300mm, whatever camera you put it on.
With the same camera, 28mm with your Sigma 28-300mm provides the same field of view as 28mm with your Sigma 17-70mm.
A lens is only "digital" because its image circle is smaller in diameter than a "film" lens. The focal length is the same if the number of mm quoted is the same.
Posted 15/02/2010 - 23:15
28-300mm on 35mm film provides proper wide angle at the short end. You were mistaken if you were expecting the same on Pentax digital. That lens is not a good choice for digital unless you don't mind having hardly any wide angle.
~Pete
Posted 15/02/2010 - 23:16
ok so both images should be the same ?, i was under the impression that the 28-300 should have some of the image slightly cropped
https://www.flickr.com/photos/carlosimagery/
http://twitter.com/foxycce
http://foxycce.ontheroad.to/carlo-does-thailand-tour
Karma is Just Cause and Effect - Do Good, Good will Happen
Posted 15/02/2010 - 23:18
i new i wasnt getting wide on the camera,hence why i have the 17-70 for my widest lens,the 300mm is just for me to have a go at captureing the moon!
Posted 15/02/2010 - 23:20
Just confused my self again, i have been with a friend of mine who has a full fram 5dmk2, he has totally confused me though, even though he ment well. grrr
Posted 15/02/2010 - 23:22
No, there's no cropping because the image circle is more than large enough to cover the digital sensor.ok so both images should be the same ?, i was under the impression that the 28-300 should have some of the image slightly cropped
It's the other way round. A digital lens can cause cropping (vignetting) on a film camera.
~Pete
Posted 15/02/2010 - 23:24
Ok, good luck with that i new i wasnt getting wide on the camera,hence why i have the 17-70 for my widest lens,the 300mm is just for me to have a go at captureing the moon!
You can forget about cropping issues unless using a "digital" lens on a film camera.
~Pete
Posted 15/02/2010 - 23:43
Reading between the lines I think organicimagery's use of the term 'cropping' is incorrect, but I think he's getting this from the frequently used term the 'crop factor'.
(For organicimagery's benefit): But this of course matters when you have a point of reference from a 35mm body. If you are only ever using digital, then there's no difference. It's when you place the same lens from a 35mm/full frame body to a cropped APS-C DSLR sensor that you notice the extra gain in apparant focal length.
Posted 15/02/2010 - 23:57
I find it helpful to think of it like this...
Imagine you have a postcard. It doesn't matter what focal length lens it was taken on. Now take a scalpel and cut out a postcard-shaped hole in the middle, 2/3rds the area of the whole. The whole postcard represents what you would have got using a 35mm camera, the bit you have cut out represents what you get when putting the same lens on an APS-C digital camera.
The only wrinkle is that if the lens is designed for APS-C, the corners of your postcard are likely to be dark.
HTH. Kris.
HTH. Kris.
Posted 16/02/2010 - 01:14
moral of the story, dont listen to canon users lol(joke by the way)
Posted 16/02/2010 - 02:30
Its all irelivant i know that, just wanted to clarify it in my head, phew.
Posted 16/02/2010 - 02:50
This is what i read made life easier, http://www.kenrockwell.com/tech/crop-factor.htm
Posted 16/02/2010 - 02:52
Ok so 28mm is wide on a full frame/35mm camera, however when on a dslr it applies a 1.5 field of view, to compensate for the smaller sensor,from old thread from hefty:
Focal length is focal length and a 300mm lens on film is still a 300mm lens on digital.
The difference is that your digital sensor "sees" a cropped part of the image projected by the lens (because it's smaller than a 35mm film area). Hence a 300mm lens fitted to a digital camera will "see" an area that's roughly the same as that "seen" by a 450mm lens on 35mm film.
A 300mm lens designed for digital will give exactly the same view as a 300mm lens designed for film on your GX10.
Does that make it clearer?
Cardiff
http://www.sigmaphoto.com/lenses/lenses_all_details.asp?id=3315&navigator=6
and have now just bought the Sigma 28-300mm Hyperzoom DG f3.5, its for 35mm but when i had a play earlier today, i set the lenses on a tripod and the took images at 28,25,and 70 and they all look the same, i thought there should of been a cropped field of view/ magnification
