Comparison of 16-50 and 16-85
Posted 25/03/2015 - 12:38
Mike-P wrote:
Welcome back George ... a passing visit or are you staying a while ?
Well, I think I might stick around. Pentax is definitely moving forward more rapidly under Ricoh than it did under Samsung, and I will be very interested to see how things develop. Also, I hope to have a bit more time on my hands this year.George Lazarette wrote:
Obviously there is no need to point out that one has a longer range!
That's me out then. Obviously there is no need to point out that one has a longer range!
Posted 25/03/2015 - 12:45
The aperture of the Pentax 16-50 is considerably better,
The updated optics of the Pentax 16-85 are better, except at the widest most range. The reliability of the newer version is simply beyond compare. The WR of the newer version is also a plus
Posted 25/03/2015 - 12:57
Thanks. It's clearly a good lens. The question is, does it produce better images than the 16-50? The increased range is of course a plus, but for me the variable (and slower) aperture cancel that advantage out. So it's really down to image quality, and the 16-50 I used to own was close to the Limiteds in that respect. I don't want to take a step backwards.
Posted 25/03/2015 - 12:59
Has it been around long enough to comment on the reliability? In what way are the optics better? Both have WR.The aperture of the Pentax 16-50 is considerably better,
Posted 25/03/2015 - 14:21
Pentaxophile wrote:
A thorough user review and comparison (with sample images) with the 16-50/18-135 here
Exactly what I was looking for. Thanks.A thorough user review and comparison (with sample images) with the 16-50/18-135 here
"So as it is, at full retail, I'd recommend the 16-85 (unless you need the f/2.8 and beefier weather resistance) and if you can get the DA* for a good deal used for less than the 16-85 (as it's too new to have any used samples available), then I'd go for the DA*."
At the moment, a second-hand 16-50 at a good price looks as though it may be the right choice. I think a glass of Bowmore is required to assist the mulling process.
Cheers.
Posted 25/03/2015 - 14:52
there is a lot of mixed reviews on the 16/50 i have just looked on dpreview and one person as said its a heap of junk anothere has said its not the best and the othere have said it is ok
where as the 16/85 is the total opposite they rave sbout it
but then the 16/50 is 7year old and the 16/85 is what abot 5 /6 month old not really been out long enough to find the problems yet
regards stu
regards stu
Posted 25/03/2015 - 15:33
Early 16-50's were plagued with SDM failures. I say 'early' because there seems to have been a fall off in complaints over time.
The US site has a list of serial numbers of lenses with failed SDM.
Posted 25/03/2015 - 15:52
regards stu
You seem to have found some very one-sided reviews. I know that early 16-50s had some AF motor problems, but the great majority of reports I have read were complimentary about the image quality.there is a lot of mixed reviews on the 16/50 i have just looked on dpreview and one person as said its a heap of junk anothere has said its not the best and the othere have said it is ok
regards stu
I had one (before I dropped it), and could scarcely tell the difference between pictures taken with it and pictures taken with Limited lenses.
Posted 25/03/2015 - 16:09
I have some 5k photographs with the newer 16-85 already. Whereas... The older 16-50 has failed me twice within two months of purchasing it, and also using it on a very "lightweight" scale.Has it been around long enough to comment on the reliability
Even seeing and using the newest off of the line run 16-50... It's just one of those lenses that can NEVER be carried around and used without worry of having it fail completely. The newer 16-85 is build considerably more durably and reliably, although those apertures are sad if not having ideal lighting
Posted 25/03/2015 - 20:02
Stuey wrote:
Good to see you around again George
Good to see you are still here!Good to see you around again George
22 years
London
I am thinking of buying one or the other. Obviously there is no need to point out that one has a longer range!
