Colour Difference
Posted 20/07/2009 - 21:34
The water probable is the colour you see in the first image, what you see in the second image is probable the reflection of the sky in the water.
Posted 20/07/2009 - 21:35
The change of angle could have something to do with it since you were using a polariser maybe?
Were they shot jpeg or RAW. If RAW then set the white balance, etc to the same level for both and see how they look then.
Posted 20/07/2009 - 21:57
I agree with Gwyn. Change of angle of polarizer.
Posted 20/07/2009 - 22:02
Thanks lads,I don't use raw much to time consuming, I may have moved the polarizer slightly but I doubt it, the only thing I can think of is the angle of the sun may have changed when I moved position other than that I have no idea,
Jack.
Jack.
Posted 20/07/2009 - 22:17
Were both images metered at the same point Jack
Posted 20/07/2009 - 22:51
More or less Martin about 10feet apart
Posted 20/07/2009 - 23:07
All i can think is maybe the camera has taken a different reading off a different area' darker or lighter it would give a different colour cast because it was in auto white balance mode.
I know this doesn't help much Jack
Posted 20/07/2009 - 23:32
Thanks Martin, I have a few more slightly different so this could be the problem, anyway it gives it a bit of variety so I can live with it,
Jack
Jack
Since everyone says it's the white balance I've uploaded them into lightroom and use the WB picker, it measure the white so to say.
I've clicked on the on the wall on the right side of the door of the house with both images.
[IMG]http://i282.photobucket.com/albums/kk244/Anvh/image1-2.jpg[/IMG]
[IMG]http://i282.photobucket.com/albums/kk244/Anvh/image2.jpg[/IMG]
It does make a small difference but surely not much so it's the change of angle.
As you can see you have far less reflections in the plants and the water with the first photo then with the second.
Posted 20/07/2009 - 23:38
Thanks Stefan, just goes to show you that light works in mysterious ways,
Jack.
Jack.
Aperture priority, F8, 1/125, ISO 200, 18mm auto white balance.
[IMG]http://i453.photobucket.com/albums/qq253/jackitec/image1-2.jpg[/IMG]
[IMG]http://i453.photobucket.com/albums/qq253/jackitec/image2.jpg[/IMG]
