Cobra 750AF flashgun and ist DL
HarryC
Posted 31/01/2006 - 22:00 Link
I have a cobra 750AF flash complete with the Pro grip bracket, that I got for use with my MZ-5N several years ago. Is this flash system fully compatible with my ist DL?
LiamD
Posted 01/02/2006 - 07:39 Link
Hi Harry and welcome.
The first thing to check when using any older, and especially non-pentax, gun on the *ist or any digital camera is the trigger voltage. You can't use a gun with greater than (I think) 30v with the *ist. I'm off to work, so if someone else could verify that figure please.
It's not listed here..
http://www.botzilla.com/photo/strobeVolts.html
so you'd need to check that first, before even plugging it into the camera. Here's how..
http://www.botzilla.com/photo/g1strobe.html
If that's all well and good, then you should be okay. Not sure about TTL compatibility, as I don't know the gun, but I'd hazard a guess that you won't get P-TTL with it.
Hope that helps.
Liam
Liam
