church shots
Posted 08/03/2009 - 20:32
Nice
One curiosity though - the exif data says the second picture was taken atF3.5. To my fairly inexperienced eye, the dof is remarkable for that large an apperture.
Posted 08/03/2009 - 20:39
The interior shot is much better than the exterior one. The exterior shot has a bland sky and converging verticals on the building. It gives us little idea of the overall structure, so I think a different viewpoint would probably be better.
The interior shot is better balanced and shows us what we need to see much better. It is leaning to the right, which is easily corrected, but is a basically sound image.
Posted 08/03/2009 - 21:54
Oggy wrote:
Nice
Oggy, you failed to look at the focal length, DoF would still be good wide open on an 18mm lensNice
Oops! sorry forgot to comment on the pics as well, the weather wasn't really on your side for exterior shots, OK for the interior though, I agree with the other comments.
Posted 09/03/2009 - 18:27
hi
thanks for the comments
yes the weather was bad just
started to rain
neil
started to rain
neil
cheers Neil
pentax k3
Panasonic Dmc Fz200
pentax k3
Panasonic Dmc Fz200
Posted 10/03/2009 - 15:36
Prefer the inside shot , lovely colours .
Tracey
K100D Super,DA 55-300.
CS3
CS3
Posted 10/03/2009 - 15:54
Agree with the others - inside photo is best. The lighting and DOF is good.
John
John
On a dark desert highway, cool Pentax K5 in my hand.
My Kit
K5 & 18-55 Kit lens, K7, Pentax 18-250mm lens, Sigma 10-20mm lens, Sigma 105mm Macro lens, Pentax 50mm 1.7 lens, Cokin P Series Filters
My Kit
Posted 10/03/2009 - 17:29
As everyone has said, inside shot much nicer. I have found that using a little hotshoe mounted spirit level helps hugely when setting up this sort of photo. Some tripod heads have built in spirit levels.
With outside shots, don't be afraid to get everything level then crop a big slice off the bottom, unless you can find something eye-catching to fill the foreground such as spring flowers or interesting tombs.
Cheers, Kris.
Cheers, Kris.
Posted 10/03/2009 - 18:49
hi
thanks again both shots
are handhald
neil
are handhald
neil
cheers Neil
pentax k3
Panasonic Dmc Fz200
pentax k3
Panasonic Dmc Fz200
Posted 10/03/2009 - 18:50
sorry forgot to ask
whats the cure for blown skies
neil
neil
cheers Neil
pentax k3
Panasonic Dmc Fz200
pentax k3
Panasonic Dmc Fz200
Posted 10/03/2009 - 19:04
gtis wrote:
sorry forgot to ask
neil
Take some photos of interesting skies that you can place in your photo instead of the blown one. Cheating but it can be effective.
sorry forgot to ask
neil
Posted 10/03/2009 - 20:09
Love the warm colour of the second shot; it is a shame that they stick those huge black speakers on those beautiful columns. Composition is not as I would have chosen but that is really for the photographer to decide.
The first is spoiled by the sky, and, my hobby horse, it does not look quite straight, if you are into PS you could improve the sky but best way would be to replace it altogether, think the large dull window do little to attract the viewer either, one could also improve them in editing but may be you feel that would be too much work, sorry, 'tis only my opinion and if you think different then ignore me. The shots taken should be taken to please the photographer first and foremost so it my opinion is just that my opinion.
Jackie H
K7, K20D, istDS, Optio SV, ME
Most used glass
50mm f1.4, 60-250mm, 28-80mm,
Most used glass
Posted 10/03/2009 - 20:38
gtis wrote:
sorry forgot to ask
neil
Expose to the right, i.e. check the histogram and make sure that there is nothing beyond the right hand edge. The photo overall may look horribly dark and under-exposed. Then use something like CS3's shadow-highlight tool to bring the shadows back. If you overdo it, however, it will look noisy. In extreme cases you might have to use a HDR (high dynamic range) program which essentially sandwiches several exposures of the same photo together.sorry forgot to ask
neil
Best wishes, Kris.
Posted 10/03/2009 - 20:41
Thordell wrote:
and, my hobby horse, it does not look quite straight...
Mine too, hence the spirit level comment. You cannot beat using a tripod for these sorts of photos.
darfield sth yorks
here are two church photos
comments please
neil
[IMG]http://i676.photobucket.com/albums/vv123/gtis/IMGP0102.jpg[/IMG]
[IMG]http://i676.photobucket.com/albums/vv123/gtis/IMGP0104.jpg[/IMG]
pentax k3
Panasonic Dmc Fz200
