Centre AF point on K-7
bettyswolloks
Posted 15/08/2012 - 17:24 Link
When using SEL for the focus point is there a way to centre it with a single button press?
It was possible on the K10 but can't find the option on the K7.
dark_mist
Posted 16/08/2012 - 14:15 Link
Press the Centre of the 4 way controller and the Centre AF point is selected.
bettyswolloks
Posted 16/08/2012 - 14:21 Link
Doesn't work mate, that just changes the use of the 4 way controls. Thanx for the reply though ;O) I dont thinks it's possible like it is on the older models.
Posted 16/08/2012 - 14:59 Link
Actually, page 129 of the K5 manual says:
OK Button: Returns the AF point to the center of the AF frame.
Press and hold OK Button: ...
(My K5 is in for repair) It may be that you need to hold down the AF button to switch the enable/disable and then pressing OK will center it.
It's probably quicker to rotate the focus point selector - because when you switch back to the choice of AF point it will have remembered where you last were
Edited by MattMatic: 16/08/2012 - 14:59
bettyswolloks
Posted 16/08/2012 - 15:38 Link
Doesn't work either Matt.
Your right, it would be just as easy to use the 4 way to centre the point again, I just seemed to use it on my K10 so I was wondering if it's possible on the 7 is all.
Been pressing and holding everything to see if it will centre the point, I think maybe I should have a pant leg rolled up while hopping on my left legs is the way forward
Posted 16/08/2012 - 16:21 Link
When I get the K5 back I'll try it out...
bettyswolloks
Posted 16/08/2012 - 16:24 Link
Fanx Pal
