K5 default values
Posted 16/08/2012 - 14:35 Link
A question for K5 owners
What were the first changes you made to the factory default settings when you bought the K5.
just curious as I have just acquired one and am about to start fiddling.
regards
ChrisA
Posted 16/08/2012 - 14:41 Link
- Turned off the beeps
- Turned off the top LCD light
- Turned down the back LCD brightness
- Switched "Use aperture ring" to "permitted" in the custom settings
Can't remember anything else
Posted 16/08/2012 - 14:46 Link
Centre point only for focus.
Centre-weighted metering.
Natural image style.
Premium JPEG quality.
Lock exposure to focus point.
Posted 16/08/2012 - 14:48 Link
Thanks Chris
I have done the beeps and allowed the use of the aperture ring. I can't think why this is not permitted by default, or even why there is a setting for it. Why would you want to disable the use of the aperture ring?
ChrisA
Posted 16/08/2012 - 15:21 Link
Because unless you know exactly how to do the metering when you use it, your exposures will be all up the swanee.
Better to default to not let the shutter fire in non-A modes IMO - then people that have a reason for using the aperture ring will go looking for it, and then discover stop-down metering.
ChrisR
Posted 16/08/2012 - 16:32 Link
K5, now twelve months old, still on factory settings, not found the need to change anything.
Also no firmware updates.
Take care.
Chris R.
I. El. (Eng). (Rtd).
wvbarnes
Posted 16/08/2012 - 17:04 Link
As well as the obvious turning off of preview screen, LCD screen light, status screen,silly bleeps, four star low compression jpeg (odd its not the default) etc
I've set up some User mode settings (you can do up to five)for fast action, landscape, night photography etc. for quick change.
I use TAV mode mostly and change to spot focus and spot AF when using telephoto.
