Camera stuck in autofocus, switch problem
Posted 18/06/2009 - 17:50
It sounds to that the switch is physically stuck. It operates the autofocus drive pin which is between 4 and 5 o'clock on the lens mount. In MF mode the pin is retracted. It might worth seeing if you can gently push it back in.
Posted 18/06/2009 - 20:38
Thanks for your help. i have tried the pin and it moves freely. I have exerted pressure on the switch at the same time and it remains stuck. I think the problem is internal and i will have to seek out a repairer.It sounds to that the switch is physically stuck. It operates the autofocus drive pin which is between 4 and 5 o'clock on the lens mount. In MF mode the pin is retracted. It might worth seeing if you can gently push it back in.
many thanks anyway.
Posted 18/06/2009 - 20:46
greynolds999 wrote:
You may well find that it will cost more to repair than the cost of the camera! You might want to get a quote from an independent first (see here).
The link is, as gartmore states, mechanical. Did you bang the pin at some point?
Hi thanks for your reply. No i have not touched the pin, but what may have happened was that I was using the camera as i thought in Manual focus when in fact it was in auto, and pressed shutter release whilst still moving the focus ring for the fleetest moment. I will contact the independent I think.
Many thanks
