camera not working/ Av flashing
Posted 02/01/2009 - 20:29
Have you done a reset to factory settings?
P179 of the manual.
Av - means you have Aperture Priority selected, or is an indication of the Aperture vale selected but the -- indicates an error. Have you checked the lens is correctly mounted and the contacts clean?
P179 of the manual.
Hi Jbrramsey welcome to the forum.
What lens do you have on the camera : Is it the kit lens :
It sounds like the lens is not communicating with the body. You need to go into the custom settings and change the (allow use of the aperture ring) too permitted. Or it could be dirty contacts on either the lens or body mount, give them both a good clean. cheers
Camera:|K-7|
Posted 02/01/2009 - 20:45
Thanks for your prompt responses. Indeed changing the lense seems to sort the problem so I think you are very much on the right lines, though I can't see anything wrong with the lense I was using.
Posted 02/01/2009 - 20:47
There is nothing wrong with the lens. You just have to change the custom setting to what I have said above and it will work fine.
Camera:|K-7|
Posted 02/01/2009 - 20:56
As Clarky said, give the contacts a clean and also exercise the aperture ring several times to ensure any internal contacts are cleaned.
Posted 03/01/2009 - 11:39
Thanks all. Clarky's suggestion rectified the problem as he so confidently predicted.
Playback works, the menu button gives a display but other controls are non-functional and it won't take pictures. The camera is not brand new and not in warranty, but is in very good condition and was working well.
Any suggestions, and what exactly does Av stand for?
