Calling K5ii/ K5iis owners - loose shutter
Posted 31/12/2012 - 23:01
I wouldn't be very happy about it.
Posted 31/12/2012 - 23:31
hmmm doesn't sound good. I'd get in touch with SRS
pretty sure my K5 doesn't make any such noises. must check my K5 11 that arrived today
Posted 01/01/2013 - 15:02
Mine is the same as my others, nothing odd about it. Give Chris a call mate, he'll have you sorted in no time
Posted 01/01/2013 - 15:04
yeah checked my newly arrived one and there's no rattle , wobble or anything
Posted 01/01/2013 - 15:09
Cheers, I'll get in touch with SRS, especially that I'm down in London
K5iis and a couple of lenses.
Posted 01/01/2013 - 15:27
In 2011 I had a similar issue with the K5 that I owned at the time. I sent it off to Johnsons who replaced the shutter button & unit due to a fault.
Hope that helps.
Hope that helps.
Posted 02/01/2013 - 16:04
Update
Just back from SRS. Looks like this is normal.
BTW, I'm talking about the actual shutter press button. The plastic button feels like it slightly floats on actual mechanism. Which was same for the demo model.
Posted 02/01/2013 - 16:07
if it makes a noise I would say it is not normal
I have a K5 and a K5 11 - neither make any noise or seem overly loose.
Posted 02/01/2013 - 16:28
Noise is perhaps a strong word.
There is a perceptible sound and it does not affect the use/function.
As I said, it was similar to the shop model.
Anyway back to the K5iis, I am really impressed. I not a pro, but the pictures are visibly sharper and a tiny bit less noisy.
But the main difference is the focussing under low light.
Posted 02/01/2013 - 16:54
glad you're liking it
Posted 06/01/2013 - 14:38
My K5iis has the same slight looseness.Doesn't affect performance? But I wonder if weather sealing is affected? Going to Antarctica soon. Would hate to find it's an issue while I'm down there!Noise is perhaps a strong word.
cheers
bb2
K5, K20D, Bigma, Sigma EX 105, Sigma EX 10-20, Sigma EX 28-70 F2.8, Sigma Ex 1.4TC,
Pentax 135 F3.5, Pentax 30mm F2.8 , Pentax 50mm F1.7, Pentax 55mm F1.8,
Super Taks: 35mm F3.5, 50mm F1.4, 135mm F3.5, 200mm F4
Vivitar TX 200mm F3.5,Vivitar (Komine)135mm f2.8, Vivitar 2X TC, Vivitar T4 400mm F6.3
Tamron SP 35-80,80-210 F3.8, Helios 44M, Mir 1B 37mm F2.8, Jupiter 9 85mm F2, Chinon 28mm F2.8, 3M-5A 500mm F8 etc etc
Posted 06/01/2013 - 21:56
I'm told it's because of the O ring seal around the shutter button.
Let us know how you get on with it in Antartica
Pentax Land
However my shutter button is a bit loose, making a clickety sound with any slight touch
Should I be concerned? Should I ask SRS for a swap?
