Buying SLR checklist.
DERYN
Posted 05/06/2013 - 19:17 Link
Hi all, if you came across a film camera for sale, let's say in a charity shop, just what would/could you look for to check the working order of the camera? I know ultimately the test would be the film test. And perhaps different cameras might have different priorities, but is there a general tick list?
Deryn
gartmore
Posted 05/06/2013 - 19:38 Link
Worn case and very good body would suggest amateur use and the opposite might indicate professional use. Take the lens off and carefully examine it from back and front in good light looking for fine lines of fungus. Check the iris opens and closes snappily and there are no traces of oil on the blades.
Open the back holding it up to the light and watch the shutter curtains, at the flash sync speed and slower you should be able to see the entire film gate.
Check the battery compartment for signs of corrosion
DERYN
Posted 05/06/2013 - 20:06 Link
Hi Ken, thanks for the input.
Where would oil on the blades come from? what type of oil?
Deryn
Jonathan-Mac
Posted 05/06/2013 - 21:11 Link
The advice from Ken is very good. I'd add that you should check the light selas and mirror buffer, though these are easy and cheap to replace, this adds to the cost of the camera. I'd also wind and fire the shutter a few times, though if it's an electronic shutter you'll need batteries. Again only if you have batteries, check the light meter works. Check that the battery compartment is not corroded.
Hardgravity
Posted 05/06/2013 - 21:44 Link
Oil on the aperture blades is usually from the manufacturing stage.
Small amounts of grease are used in various parts of the lens body, these tend to find there way through to the blades.
It isn't a problem on Rangefinder lenses, but on a SLR lens it slows the action down causing over exposure.
The oil can be cleaned of by brave /competent tinkerers.
As for SLR cameras, I tend to avoid any fully electric bodies if they don't have working batteries installed.
Cheers, HG
PPG entries.
DERYN
Posted 06/06/2013 - 20:41 Link
Thanks all.
This really came about because in the past I have seen an SLR film camera or two in charity shops but never checked them out. Next time I just might check them out and see what I find. Now I have a good idea of what to look for.
Deryn
