Buying a spare battery
- Topic Locked - You will not be able to post to this topic. Thread in discord
Posted 13/05/2012 - 13:45
coker wrote:
Have a look in 7dayshop, Patrick.
I've had one for my K7 for some time & all seems well with it.
Roger.
Yes same hear!Have a look in 7dayshop, Patrick.
Roger.
Kindest regards.
Posted 16/05/2012 - 08:36
I have a compatible battery, and it's just fine.
But if you are getting a compatible battery, do check the specifications carefully and make sure you are getting like for like. Then you shouldn't have any problems.
Many compatibles are cheaper because they have lower capacities and outputs. They will still work, but just won't last as long.
Posted 16/05/2012 - 19:19
Smeggypants wrote:
I have read and heard a lot of issues with batteries purchased on e-bay, which are in fact duds, or have caused damage to the camera in question. Offertonhatter wrote:
I have one for the K10D/K20D and one for the K-5.
I have found that they work just as well as OEM ones.
As for batteries from E-bay, I am always wary, as they could be problematic.
So I try and go for known brands from reputable sources. So either OEM or brands such as Hahnel, Uniross etc.
On what basis?wvbarnes wrote:
SRS promote Hahnel replacements.
Second on the Hahnel batteries.SRS promote Hahnel replacements.
Sure, it might be very rare, but it is something that makes you think. Hence why I always purchase something like a battery from a reliable source.
Some Cameras
Posted 16/05/2012 - 20:51
I have not had problems with compatibles for my Canon kit - indeed the Duracells (£12 instead of around £80/90) seem to hold charge for longer when not in use and last at least as long in use - probably more.
Same cannot be said of ones I bought for my K5 - my Pentax battery ran down while out and about and the compatible one I placed in the camera (fully charged night before) was showing very low after less than 8 or 10 shots !!!!!!
I bought three so hopefully that one is a one off
Posted 17/05/2012 - 09:53
I have two Pentax chargers, four Pentax batteries, one Innov8 battery.
All chargers and batteries numbered so that any fault is traceable and batteries rotated.
The innov8 battery is noticeably less efficient than the Pentax ones, but if that was all you were using you wouldn't notice any difference.
Posted 19/05/2012 - 00:44
well, if you don't want to spend £50 on Pentax one, buy from Amazon, it's £31 there But still about 6x more than a no-name one.
Pentax K-5 and co.
Posted 19/05/2012 - 10:33
I've a couple of Innov8 batteries for the K-5 - yes, they don't last quite as long as the Pentax one, but the two of them cost less than half that of one Pentax item! And, otherwise, no problems so far.
Posted 19/05/2012 - 11:21
I have used batteries from Ebay for some years for my cameras, normally buy from 1 supplier, their high capacity ones last longer than the Pentax /branded ones, never had any problems.
Dave
Dave
Auto110,MZ-30, K5, loads of Black Tubes with Glass in.
Posted 19/05/2012 - 12:08
Which supplier please Dave?
My spare is an Innov8. I've had it 18 months or so and it now won't hold much of a charge at all so I need something else.
Posted 19/05/2012 - 12:24
Dave
Can you tell us who that supplier is?
Dave
Posted 19/05/2012 - 12:54
I'm looking at a second charger for my K5 batteries. The original Pentax charger has three terminals marked, "- T +". The aftermarket versions seem to omit the "T" but say they will operate fine without. Can anybody tell me what the "T" terminal is for?
Barrie - Too Old To Die Young
Posted 19/05/2012 - 13:11
Thermistor (or temperature, I guess). I'm looking at a second charger for my K5 batteries. The original Pentax charger has three terminals marked, "- T +". The aftermarket versions seem to omit the "T" but say they will operate fine without. Can anybody tell me what the "T" terminal is for?
It allows monitoring of the temperature of the battery during charging.
Posted 19/05/2012 - 13:46
It stops the battery going... Bang!....Boom!.... bursting into
Flames! etc.
Flames! etc.
Posted 19/05/2012 - 18:13
Flames! etc.
Yup, probably is - OTOH, I lost or mislaid the original Pentax unit and bought something like bforbes described. Appears to work OK with both the original & Innov8 batteries with no obvious signs of overheating.It stops the battery going... Bang!....Boom!.... bursting into
Flames! etc.
John
Smegland
