Buying a reflector- basic questions
The Square ones will reflect more light as their area will be larger than a circular one.
If your not wishing to spend a lot, some pieces of White / Black card will do as good a job, much cheaper, then cover one side in tin foil and you have a silver reflector, although scrunch it up first otherwise its a big mirror.
Samyang 14mm F2.8, Pentax DFA* 70-200 F2.8
Having used many, both my own and others, they are much of a muchness, the only difference between the square or circular ones other than the obvious will be how the catch lights appear in your subjects eyes.
I am a great fan of large sheets of cardboard, actually mat black on one side and white on the other doubles up as a useful background when not used as a reflector. However I also keep a small pop-up reflector in my bag - in my case ircular
https://www.flickr.com/photos/arleimages/
Good idea, I'll try it out. Although I was looking forward to buying a new (in this case shiny) toy. Better to try the cardboard and foil though, see how helpful it is.
On a lighter note. Buy some smoked salmon and you'll find it is on a card which is silver on one side and gold on the reverse. only about 10inches x 12 inches. BUT you do get to eat the salmon.
CHEERS Vic.
Also the all in ones often have a white diffuser, which can be really useful if you are outside in bright sunlight.
13 years
I'm going to buy a reflector, plan to use it for shooting my family at home (baby on the way soon, 2 kids already).
Are 'they all the same' within a prince range or are some better than others? Is a rectangular one better than a round one?
I don't plan on spending a lot on one at this current time.
Thanks in advance,
Pa.
Pa
