Blue tint from a polarizer
Posted 26/06/2009 - 17:59
looks to me like you got blue water reflecting off the white plumage...
select the areas in photoshop, and desaturate the blues.
Posted 26/06/2009 - 18:26
I'd say it was due to the white chest reflecting the blue sky, and your white balance being set on either auto or sunny. The shot over all looks a little cool, but changing the white balance to shade would probably make the rock and sunlit areas of the birds too warm looking.
The underside of the bird looks whiter because the warm coloured rock is bouncing light back up, but the blue areas are only recieving light from the blue sky.
So nothing to do with the polariser, I'd say.
Dan
Dan
Posted 26/06/2009 - 20:32
I'm struggling to see anything wrong.
It looks like normal strong daylight to me.
I would be more concerned with the focus, but it's a nice shot.
Posted 27/06/2009 - 06:09
The focus seems slightly off to me.A nice image though
Posted 27/06/2009 - 08:00
Thanks far all the constructive help, I am constantly impressed as to how helpful everyone is on this site.
Don: I'll fire up Photoshop and give that a go.
Dan: Thanks for the link it was most illuminating if you forgive the pun.
Do you think I should have used a different white balance setting to compensate?
Darkmunk & Martin:
Thanks Again
Darkmunk & Martin:
Sanderscapes wrote: The focus seems slightly off to me. A nice image though
Best regards from
Martin @ Sanderscapes.com
I used my Sigma 70-300 f5.6 for this shot and it is proving the a constant frustration, if I don’t shoot at around f8 the focus gets even worse. Any suggestions on how I could tweak the camera to compensate or do I drop it in a skip and start again.Sanderscapes wrote: The focus seems slightly off to me. A nice image though
Best regards from
Thanks Again
Posted 27/06/2009 - 09:10
At 300mm this is an extremely long lens and inevitably, even stopped down, the DOF is wafer thin so focus has to be extremely accurate and the camera should be on a tripod. I think aerial haze is apparent in your picture and a UV or skylight filter might have been more useful than a PL which is going to exacerbate the DoF/steadiness problem.
Posted 27/06/2009 - 13:43
Thanks gartmorem, the irony is I took my UV filter off in preferance to my polorizer.
Regarding the tripod, I took a series of experimental shots with my camera mounted. They were all set too manual focus, 250mm, iso 100, shake reduction off and every f stop the lighting conditions allowed. The result was always the same, poor focus. At first I thought it could be a problem with the cameras viewfinder however carrying out the same tests with my 18-55 kit lens rules this out. Any thoughts on how I could confirm where the fault lies, me, the lens, the camera.:
Posted 27/06/2009 - 13:49
Have you got the eyepice dioptre set accurately? Point the camera at a blank surface and as out of focus as you can make it, then adjust the dioptre until the viewfinder graticules are as sharp as possible.
Sometimes using a tripod just isn't quite enough, if you are on a wooden floor or spongy grass people walking around nearby can cause enormous shake; likewise, a windy location, perhaps yours, can cause it too.
It might then be worth carefully photographing a newspaper pinned to a wall before examining anything else.
There is dirt on you sensor too!
Posted 27/06/2009 - 15:52
Your focus is off, the DOF lie directly behind the bird.
If you look had the birds feet and then to the rock on the right of that you can clearly see it.
Remember that the DOF at 55mm is quite a lot wider then DOF at 250mm with the same aperture.
Posted 27/06/2009 - 21:27
Ken: I'll have a go with the dioptre tomorrow and see if life gets any better.
Stefan: I have looked at the original raw file and I think you are right.
Thanks again for all your help
Posted 28/06/2009 - 01:17
Thanks Again
It's quite a long lens and i've found it can waiver around a bit with that and any breezes or wind to take into consideration.I used my Sigma 70-300 f5.6 for this shot and it is proving the a constant frustration, if I don’t shoot at around f8 the focus gets even worse. Any suggestions on how I could tweak the camera to compensate or do I drop it in a skip and start again.
Thanks Again
But if you think the lens would benefit from being re-calibrated by sigma i would do it for your own peace of mind
Posted 28/06/2009 - 08:29
Thanks Martin, I will give the dioptre a go today and see what happens, if this does not work then I will contact Sigma. When this shot was setup the puffins eye was dead centre in my viewfinder (I cropped the image to remove dead space) and is in the centre of the RAW file. However as Stephan pointed
Posted 28/06/2009 - 09:28
Found this information on the pentax
I am focusing on a persons eyes but am finding in the image their ears are the sharpest point in the picture. Is my lens faulty.
This is a phenomenon with digital SLRs. If the image sensor is fractionally out of alignment, even by microns, the point of focus will not fall exactly on the sensor. The first thing to do is get the focus flange distance and AF sensitivity of your camera checked by the camera manufacturer. Getting this flange distance corrected normally solves the problem however if the problem persists, we will need your camera and lens sent in so we can set the lens to your camera. If your camera is not reset first we may be setting your lens to a camera that is not to specification, which would mean your lens will not focus accurately with any other camera. Depending on the focal length and maximum aperture of the lens, the focus problem issues can be more apparent with some lenses than others.
Somewhere at the back of my mind
link
