Birds!
Posted 06/10/2021 - 20:22 - Helpful Comment
I would suggest exposure is the easiest thing to get right. Is the light falling on each of the 5 perches the same ? If so, then work out in advance what exposure is required by using spot metering to get the branch correctly exposed. This seems to equate well with the bird being exposed right too. having established that you then use manual exposure and do not change it. If the background is going to be overexposed with these settings then underexpose by 1 or 2 stops. You can brighten the bird later in pp. Use the histogram to evaluate your test shots before the bird even appears.
Posted 06/10/2021 - 20:26 - Helpful Comment
For autofocus, i doubt single AF point will work unless the bird sits still for more than a few seconds. Can you set your camera to 9 central AF points ? In AFC mode this should work best.
I guess you are unable to pre-focus if the 5 perches are all different distances from you.
Posted 06/10/2021 - 21:55
Thanks. So, I'll try and use the multiple central AF points in AFC mode and I'll work on the manual exposure testing and settings.
Was going back tomorrow morning BUT smells like the slider on the front left brake caliper is sticking and the disk brake was very hot after a 10 mile journey.
Looks like that will have to be my priotiy tomorrow
Posted 07/10/2021 - 10:17 - Helpful Comment
Up until the K3 (3) imo Pentax autofocus/tracking has been pretty average at best and that's putting it politely and as far as I am concerned the jury is still out on the newest camera.
When shooting birds with my K-1 i use back button focus, single af point, average exposure and AF.C, multiple point is next to useless.
If you use spot exposure you will nearly always get a blown sky in the UK (same with airshows) but at the end of the day it's the detail in the bird you are after not the sky but using average normally enables you to pull more in PP.
I would also be shooting wide open and a faster shutter speed with Kingfishers, they are twitchy little buggers.
Also turn OS/SR off at those shutter speeds if you have it on.
Posted 16/03/2023 - 03:44
Glad to have come across this thread.
Am facing similar issues - very few keepers among bird pics..
Will try suggestions in above posts.
Wondering why SR should be turned off with high (how high is high?) shutter speeds... and would it affect negatively if kept on?
Also need to figure out if my lens is focussing correct, or is there some front/back focussing issues... but am not sure how to do this quickly (no short cuts there I guess...)
Regards,
Sridhar
Regards,
Sridhar
Posted 16/03/2023 - 22:59 - Helpful Comment
For birding, I usually use the K3 III with the 60-250 or the 150-450 lens. Exposure is set manually most of the time, but I use the green button to quickly reset the exposure if needed. Light metering is set to Highlight-Weighted to avoid blowing the highlights, with (sometimes) some positive exposure compensation. I "preset" the focus to somewhere close to where I think the action will be, and, depending about background or clutter, use single point or nine point AF. I also ALWAYS use a monopod while birding. I helps a lot with the 60-250, but is an absolute must with the 150-450. I often crank up the ISO to 3200 or higher to get as fast a shutter speed as I can, while haveng an aperture small enough to have some DOF,
For more "tricks of the trade", see this fellow's You Tube channel:https://www.youtube.com/@simon_dentremont/videos
11 years
Twas a cloudy, overcast day with poor light - my settings were 1600 ISO, 1/1000 sec and f6.3 using the Sigma 50-500mm lens at the 500mm end.
I tried to use the spot meter for exposure and the lake/water background was, obviously, very bright.
Also used the centre spot for the focussing today.
Obviously the kingfisher is a very small, and fast, bird in the scene.
There are 5 perching posts the kingfisher can choose and so it is not possible to use a tripod and a prefocussed and exposed test shot as it moves from one to the other/s.
Would I be better using the more general multi-segment auto-focus points and a more general exposure cluster point setting rather than the spot functions?
At least we don't have to worry about the cost of film and developing nowadays!
Any tips please?
